/var is filling up. how do you verify Nagios is cleaning
[email protected]
Post by [email protected] »
I see my file system is filling up. Checking Nagios /var/log/mysqld.log I see this error
"[ERROR] /usr/libexec/mysqld: Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed"
Checking file system I see.
ls -lha /var/lib/mysql/nagios/nagios_logentries.*
-rw-rw---- 1 mysql mysql 8.8K Jan 7 11:34 /var/lib/mysql/nagios/nagios_logentries.frm
-rw-rw---- 1 mysql mysql 21G Apr 8 14:02 /var/lib/mysql/nagios/nagios_logentries.MYD
-rw-rw---- 1 mysql mysql 9.7G Apr 8 16:09 /var/lib/mysql/nagios/nagios_logentries.MYI
I am currently doing a check for more information.
[root@LNTTAVMNAG2 /]# mysqlcheck -r -f -u root -pnagiosxi --databases nagios nagiosql
Can you supply a reference on how to identify the cause and how to clean and fine tune Nagios logs?
jdalrymple
Skynet Drone
Re: /var is filling up. how do you verify Nagios is cleaning
Post by jdalrymple »
What do your TABLE TRIMMING OPTIONS look like in /usr/local/nagios/etc/ndo2db.cfg?
defaults:
## TABLE TRIMMING OPTIONS
# Several database tables containing Nagios event data can become quite large
# over time.  Most admins will want to trim these tables and keep only a
# certain amount of data in them.  The options below are used to specify the
# age (in MINUTES) that data should be allowd to remain in various tables
# before it is deleted.  Using a value of zero (0) for any value means that
# that particular table should NOT be automatically trimmed.
# Keep timed events for 24 hours
max_timedevents_age=1440
# Keep system commands for 1 week
max_systemcommands_age=10080
# Keep service checks for 1 week
max_servicechecks_age=10080
# Keep host checks for 1 week
max_hostchecks_age=10080
# Keep event handlers for 31 days
max_eventhandlers_age=44640
You may want to run the database repair script too...
https://assets.nagios.com/downloads/nag ... tabase.pdf
On a db that size though it could take awhile.
Also you can set the auto trim level for that table here in the web UI
Admin -> Performance Settings -> Databases Tab -> NDOUtils Database section
Reduce "Max Log Entries Age:"
