apply reconfiguration fails on nonexistent object
kendallchenoweth
Post by kendallchenoweth »
When I try to apply configuration I get an error about a service object and associated hostgroups. So i deleted that service object and applied configuration again. This service object doesn't exist in the etc/services, but I get an error that this object fails validation still. Clearly something is cached somewhere. How can I clear the Nagios object cache in order to restart without this object and then I can bring in the hosts, hostgroups and service separately to figure out what's wrong with them.
Thanks!
abrist
Red Shirt
Re: apply reconfiguration fails on nonexistent object
Post by abrist »
This could actually be a sudoer problem as well. What is the output from running the following from the cli:
cd /usr/local/nagiosxi/scripts/
./reconfigure_nagios.sh
kendallchenoweth
This is wierd... reconfigure_nagios.sh doesn't show an error.
URL: https://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=guo64u' -O nagiosql.login--2015-05-15 14:18:57--  https://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:443... connected.
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=MA/L=Natick/O=the MathWorks/OU=SSG/CN=ec2-50-19-171-201.compute1.amazonaws.com/[email protected]”:
  Self-signed certificate encountered.
WARNING: certificate common name “ec2-50-19-171-201.compute1.amazonaws.com” doesn’t match requested host name “localhost”.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
    [ <=>        ] 10,409      --.-K/s   in 0.02s
2015-05-15 14:18:57 (559 KB/s) - “nagiosql.login” saved [10409]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: https://localhost/nagiosxi/includes/components/ccm/
Array
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=guo64u' -O nagiosql.login--2015-05-15 14:18:58--  https://localhost/nagiosxi/includes/components/ccm/
2015-05-15 14:18:58 (555 KB/s) - “nagiosql.login” saved [10409]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: “nagiosql.export.monitoring”
    [      <=>        ] 13,265      2.78K/s   in 4.7s
2015-05-15 14:19:03 (2.78 KB/s) - “nagiosql.export.monitoring” saved [13265]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
	Checked 464 services.
	Checked 113 hosts.
	Checked 113 host groups.
	Checked 31 service groups.
	Checked 31 contacts.
	Checked 23 contact groups.
	Checked 197 commands.
	Checked 11 time periods.
	Checked 24 host escalations.
	Checked 12034 service escalations.
	Checked 113 hosts
	Checked 0 host dependencies
	Checked 11 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
RET: 0
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
Stopping ndo2db: done.
Starting ndo2db: done.
Stopping ndo2db: head: cannot open `/usr/local/nagios/var/ndo2db.lock' for reading: No such file or directory
done.
[nagios@ip-10-5-189-249 scripts]$ exit
Script done, file is typescript
[nagios@ip-10-5-189-249 scripts]$ more typescript
Script started on Fri 15 May 2015 02:18:55 PM EDT
[nagios@ip-10-5-189-249 scripts]$ ./reconfigure_nagios.sh
CMDLINE
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=MA/L=Natick/O=the MathWorks/OU=SSG/CN=ec2-50-19-171-201.compute1.amazonaws.com/e
[email protected]”:
LOGIN SUCCESSFUL!
Array
SETUID ROOT OK
RESETTING PERMS
CMDLINE
[email protected]”:
LOGIN SUCCESSFUL!
CMDLINE:
[email protected]”:
    [   <=>        ] 8,278       --.-K/s
OUTPUT:
Nagios Core 4.0.8
License: GPL
Checking objects...
	Checked 113 hosts.
	Checked 113 hosts
Total Warnings: 0
Total Errors:   0
RET: 0
If I click "Apply Configuration", it fails. I haven't made any changes between reconfiguration updates.
Error: Could not find any hostgroup matching 'motw_aps-broker-prod-useast1' (config file '/usr/local/nagios/etc/hosts/aps-authnz-prod-useast1_1.cfg', starting on line 16)
Error: Failed to process hostgroup names for host 'aps-authnz-prod-useast1_1' (config file '/usr/local/nagios/etc/hosts/aps-authnz-prod-useast1_1.cfg', starting at line 16)
/usr/local/nagios/etc/hosts/aps-authnz-prod-useast1_1.cfg doesnt exist in /usr/local/etc/hosts and is marked for revomal (active: no/red).
If
ssax
Dreams In Code
Post by ssax »
Try to su to nagios and run a reconfigure and see if that fails for you:
su - nagios
Might also want to check if you have an /etc/sudoers.d/nagiosxi file.
- If that file exists, view your /etc/sudoers file and see if the XI entries are at the bottom.
- If the XI entries are in the bottom of your /etc/sudoers, delete the /etc/sudoers.d/nagiosxi file and try to apply config again.
ssax
Dreams In Code
Post by ssax »
You could also try going to Configure > Core Config Manager > Tools > Write Config Files
- Click Delete
- Click Write
- Click Verify
If you get any errors, post the full output, if not, try to apply config.
kendallchenoweth
Here's an update on where I stand in this problem.
I've copied out all of my current environment cfg files into a backup directory.
I deleted all of the objects from the CCM.
I imported the default set of objects into nagios.
I will re-import my current environment once I resolve the problem.
Now here is where it gets interesting.
The objects import into nagiosql and generate files in /usr/local/nagios/etc.
/usr/local/nagios/nagios/bin/nagios -v /usr/local/nagios/etc/ returns 0 warnings or errors.
http://<host>/nagios shows the default configuration
http://<host>/nagiosxi now shows the default configuration
The result from "apply configuration" returns an error
Error: There are no services defined!
Error: There are no hosts defined!
Error: Service notification command 'xi_service_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Error: Host notification command 'xi_host_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Error: Global host event handler command 'xi_host_event_handler' is not defined anywhere!
Error: Global service event handler command 'xi_service_event_handler' is not defined anywhere!
But these objects do exist!
Command Name Command Line Active Actions ID
xi_service_notification_handler /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=service --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --service="$SERVICEDESC$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --datetime="$LONGDATETIME$" Yes EditCopyDownloadInfoDelete 314
xi_host_notification_handler /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=host --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" --datetime="$LONGDATETIME$" Yes EditCopyDownloadInfoDelete 312
xi_host_event_handler /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=host --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" Yes EditCopyDownloadInfoDelete 311
xi_service_event_handler /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=service --host="$HOSTNAME$" --service="$SERVICEDESC$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" Yes 313
The host has a status of "not applied"
localhost localhost Yes Not Applied 222
Ditto for the services.
Config Name Service Description Active Status Actions ID
localhost_services Current Load Yes Not Applied 793
localhost_services Current Users Yes Not Applied 794
localhost_services HTTP Yes Not Applied 795
localhost_services PING Yes Not Applied 796
localhost_services Root Partition Yes Not Applied 797
localhost_services SSH Yes Not Applied 798
localhost_services Swap Usage Yes Not Applied 799
localhost_services Total Processes Yes Not Applied 800
ssax
Dreams In Code
Post by ssax »
Did you do these things I asked?
ssax wrote:Try to su to nagios and run a reconfigure and see if that fails for you:
su - nagios
kendallchenoweth
reconfigure_nagios.sh does NOT fail.
There is no sudoers.d/nagiosxi file. The NAGIOSXI entries are in the /etc/sudoers file.
What's different about clicking on "apply configuration" vs running reconfigure_nagios.sh?
/etc/sudoers file
User_Alias      NAGIOSXI=nagios
User_Alias              NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/nmap *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/nmap *
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh
ssax
Dreams In Code
Post by ssax »
But did you run "su - nagios" before running the reconfigure command?
The apply configuration essentially runs: cd /usr/local/nagiosxi/scripts && ./reconfigure
kendallchenoweth
I logged in as the user nagios and ran the reconfigure_nagios.sh command as the user nagios.
