More than one system icon next to host
jkinning
Post by jkinning »
Within the CCM under the hosts and Misc Settings you can specify a png for an icon image and status image. Is it possible to have multiple images for a system? For example we run both IIS and Apache web servers. I have a single hostgroup called Webservers which it would be nice to see which ones are Windows and which ones are SUSE along with the webserver server icon. Another example would be MySQL and SUSE so I could see the icons and know it is a SUSE and not Red Hat running MySQL just by looking at the Dashboard view. I know the majority of our systems but for others this would be beneficial but I am unable to figure out if it is possible. I have tried several different combinations and they all just display an image placeholder type icon.
Re: More than one system icon next to host
Are you talking about the icons next to the hosts under the "Host Detail"? See below:
jkinning
Post by jkinning »
Yes, is it possible to have more than one? In your images example can you have both the Windows and SUSE icons for one host?
I don't think this is possible, at least I was not able to make it work. I may be wrong though. I will discuss it with our developers to see if they think it is possible.
jkinning
Post by jkinning »
I couldn't get it either but was able to have the host have one icon and then a service another for a web service for example.
Is there a listing of all the icons that are available?
Post by Box293 »
All of the available icons are here:
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/images/logos/
jkinning
Post by jkinning »
Thanks. Feel free to close.
