Below is the error received while "Apply Configuration" in the Nagios XI GUI.
Error: Service description, host name, or check command is NULL
Error: Could not register service (config file '/usr/local/nagios/etc/services/backup-server-sin.cfg', starting on line 185)
* Tried to check in host.cfg, hostgroups.cfg all fine
* In backup-server-sin.cfg file, line 185 is empty line
* Tried to remove couple of services from backup-server-sin hosts still the same issue
Error: Service description, host name, or ...command is NULL
gsl_ops_practice
Last edited by gsl_ops_practice on Tue May 19, 2015 9:15 am, edited 1 time in total.
gsl_ops_practice
Re: Error: Service description, host name, or ...command is
Fixed ,
In /usr/local/nagiosxi/scripts/restart_nagios_with_export.sh
From
sudo $BASEDIR/manage_services.sh restart nagios
To
From
To
I believe this is correctly set in the latest release.
Are we clear to close this thread?
