Configurating NRPE Agent.
monitoreo1
Post by monitoreo1 »
Hi Again !!!!!
Do you know if is possible install the NRPE agent without dependences with the "xinetd" service?
Thanks for your help.
We are Using:
Nagios XI Version : 2014R2.6
x86_64
Red Hat Enterprise Linux Server release 7.0 (Maipo)
jdalrymple
Skynet Drone
Re: Configurating NRPE Agent.
Post by jdalrymple »
xinetd is not a prerequisite for nrpe, it can be run as a daemon. I have some simple instructions I wrote up:
1) Disable the xinetd version and restart xinetd:
i - open the file /etc/xinetd.d/nrpe in your favorite editor
ii - replace the line:
       disable         = no
with:
        disable         = yes
iii - restart xinetd:
sudo /etc/init.d/xinetd restart
2) Install the nrpe startup script if you don't already have it:
i - look in /etc/init.d/ for a file named nrpe
ii - if you don't have the file create a text file and copy the contents of the included attachment into it (don't just scp the file, you could end up with broken line endings)
iii - make sure that the file is set to 755 permissions and is owned by root.root
chmod 755 /etc/init.d/nrpe
chown root.root /etc/init.d/nrpe
iv - enable nrpe at boot
chkconfig nrpe on
3) Verify that your config is OK - Open your nrpe.cfg (usually at /usr/local/nagios/etc/nrpe.cfg) and verify the allowed_hosts line reads as you wish. This line is ignored when running from xinetd so it's important to verify. The settings from before can be gotten from the /etc/xinetd.d/nrpe file.
4) Start NRPE
/etc/init.d/nrpe start
5) Ensure that NRPE is up and running.
ps -ef | grep nrpe | grep -v grep
sureshvarthi
Post by sureshvarthi »
There is not attachment for nrpe init.d script
could you please attach it
The init.d script can be found below -
https://exchange.nagios.org/directory/P ... pt/details
