I am trying to get the correct synxtax for a performance counter check. The printer queues exist but apparently I am missing something... Some help would be appreciated. This is a windows 2008 Server I am dealing with.
[root@ ~]# /usr/local/nagios/libexec/check_nrpe -H <servername> -t 60 -c CheckCounter -a "\Print Queue(BIS019PR01-Cold)\Jobs" MaxWarn=4 MaxCrit=6
No counters specified: add counter=<name of counter>
proper performance counter check syntax?
- Box293
- Too Basu
Re: proper performance counter check syntax?
You are missing Counter= from your command, it should be:
My example:
Using ShowAll adds more information:
You can also "Name" the output to something more friendly, this is done by adding the text between Counter and = using a colon (:), for example:
/usr/local/nagios/libexec/check_nrpe -H <servername> -t 60 -c CheckCounter -a "Counter=\Print Queue(BIS019PR01-Cold)\Jobs" MaxWarn=4 MaxCrit=6Code: Select all
Command:
check_nrpe -H win2008r2-01 -c CheckCounter -a 'Counter=\Print Queue(Microsoft XPS Document Writer)\Jobs' MaxWarn=4 MaxCrit=6
Output:
OK all counters within bounds.|'\Print Queue(Microsoft XPS Document Writer)\Jobs'=0;4;6Code: Select all
Command:
check_nrpe -H win2008r2-01 -c CheckCounter -a 'Counter=\Print Queue(Microsoft XPS Document Writer)\Jobs' MaxWarn=4 MaxCrit=6 ShowAll
Output:
OK: \Print Queue(Microsoft XPS Document Writer)\Jobs: 0|'\Print Queue(Microsoft XPS Document Writer)\Jobs'=0;4;6Code: Select all
Command:
check_nrpe -H win2008r2-01 -c CheckCounter -a 'Counter:XPS Document Writer=\Print Queue(Microsoft XPS Document Writer)\Jobs' MaxWarn=4 MaxCrit=6 ShowAll
Output:
OK: XPS Document Writer: 0|'XPS Document Writer'=0;4;6As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Thank you! This was very helpful!
Do you have any further related questions emartine?
Nope. We are good with this one. Please feel free to lock this.
