log file monitoring
maddev
log file monitoring
Post by maddev »
I have a fresh install of XI in place with which I would like to monitor a log file present on remote node(linux and windows).
How do I go about it. I saw check_log and check_logfiles plugins available in my XI machine where as only check_log is present in the remote machine which has NRPE installed.
I am looking for a step by step guidance on this. Whatever I tried foo last 2 days did not yield any results.
jolson
Attack Rabbit
Re: log file monitoring
Post by jolson »
What I would do in this case is get on your remote host and begin crafting the command that you want to run. The first thing I would do is pull up the help page for check_log:
[root@localhost ~]# /usr/local/nagios/libexec/check_log -h
Usage: check_log -F logfile -O oldlog -q query
Usage: check_log --help
Usage: check_log --version
If this will work for your purposes, try a few commands on the remote machine to ensure that it will work fine. Some example commands:
/usr/local/nagios/libexec/check_log -F /var/log/httpd/error_log -O oldlog -q error
/usr/local/nagios/libexec/check_log -F /var/log/cron -O oldlog -q concern
check_log3 is a little more feature-rich if you're looking for something more advanced: https://exchange.nagios.org/directory/P ... pl/details
Once you have crafted the appropriate check (or checks) on your remote box, report back with what they look like and we'll take it from there.
Twits Blog
maddev
Post by maddev »
Hi Jolson,
Thank you for the response.
check_log3 seems great and feature rich; I am going to move forward with this. I have copied the check_log3 to one of my linux node; please see below the output for a basic check command executed locally on the node.
 ./check_log3.pl -l /var/log/messages -p error -p warning
WARNING: Found 1 lines (limit=1/0): May 26 03:43:35 testbox00 ndo2db: mysql_error: 'MySQL server has gone away'|lines=1
I am not able to get the same executed through NRPE;
below is what I did in CM new service
check command: check_nrpe
arg1 : check_log3.pl
arg2 : -a '-l /var/log/messages -p a'
Output seems to be as below
COMMAND: /usr/local/nagios/libexec/check_nrpe -H testbox -t 30 -c check_log3.pl -a '-l /var/log/messages -p a'
OUTPUT: NRPE: Command 'check_log3.pl' not defined
I did not do any changes in nrpe.cfg or any other files for that matter
https://assets.nagios.com/downloads/nag ... utions.pdf
Bottom of page 9.
maddev
Post by maddev »
Thank you very much tmcdonald. I was able to configure log monitoring successfully on linux.
How to achieve the same in windows machines where I use nsclient++
jdalrymple
Skynet Drone
Post by jdalrymple »
That would be a new topic as nsclient++ has it's own event log monitoring built in. I'm assuming that's what you want?
[/modules]
CheckEventLog = 1
Is it OK to lock this one?
maddev
Post by maddev »
No; What I am looking for is monitoring application log files in windows for patterns as we just did on linux using log3.pl
jolson
Attack Rabbit
Post by jolson »
You can definitely use check_log3.exe, which can be downloaded here - this can be called through NSClient and monitors flat files for strings: http://sourceforge.net/projects/pma-oss ... s-plugins/
If you're talking about Windows event logs, that's a little bit different. NSClient can be used to monitor event logs: http://docs.nsclient.org/reference/CheckEventLog.html
Let us know if you need additional help!
Twits Blog
maddev
Post by maddev »
Hi Jolson,
Link for check_log3 is good, documentation is extensive. But I am not that nagios aware. Can you guide me through where should I place the check_log2.exe, which files to modify and what should be the configuration in XI service
jdalrymple
Skynet Drone
Add this to your nsclient.ini:
[/modules]
CheckExternalScripts = 1
check_nsclient_log=scripts\check_nsclient_log.bat
Create scripts\check_nsclient_log.bat with the following contents:
"c:\Program Files\NSClient++\scripts\check_log3.exe" -l "c:\Program Files\NSClient++\nsclient.log" -p "Failed"
Copy check_log3.exe to scripts\
[jdalrymple@localhost libexec]$ ./check_nrpe -H <winhost> -c check_nsclient_log
C:\Program Files\NSClient++>"c:\Program Files\NSClient++\scripts\check_log3.exe" -l "c:\Program Files\NSClient++\nsclient.log" -p "Failed"
WARNING: Found 3 lines (limit=1/0): 2015-05-28 12:27:15: error:D:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: help|'lines'=3
OK: Found 0 lines (limit=1/0): No matches found.|'lines'=0
Simple example - adjust to suit your needs.
