Disable Problem Acknowledged Notification
paulol
Post by paulol »
There are anyway to disable the notification for "Problem Acknowledged"? Because im receiving duplicate notifications with this.
1. I receive a notification for DOWN Problem.
2. When i put the Host in Acknowledged, nagios send me another notification about same problem.
Following the image:
Re: Disable Problem Acknowledged Notification
Are you saying that when the problem is Acknowledged, you do not want to receive a notification?
If so, when a problem is acknowledged, uncheck the "Send Notification" box and then Commit it.
paulol
Post by paulol »
Sorry, i didnt see :shock: ,
But there are anyway to uncheck to default this box "Send Notification" ?
thank you tgriep.
I don't think you can without recompiling Nagios however, in the future releases of XI, users will have the option to enable/disable acknowledgement notifications.
paulol
Post by paulol »
OK, thankou.
Can we close the post?
paulol
Post by paulol »
yes.
