Need help using check_logfiles
tgfde
Post by tgfde »
I'm in the process of getting Nagios to start monitoring events via Event Log. However, after configuring the 'EventLog.txt' (attached) file to monitor an event, I get a "UNKNOWN - configuration incomplete" status. I'm sure I'm missing something.
I used the command below to check for the event:
./check_nrpe -H $HOSTADDRESS$ -u -t 30 -c check_logfiles -a EventLog.txt $ARG3$
Thanks.
tgfde
Re: Need help using check_logfiles
Post by tgfde »
I also have the attached file is another option but it is not detecting the event. Although, it is not giving me an error when I use this file, it just shows everthing is ok.
Thanks.
mguthrie
Post by mguthrie »
What check plugin is this using on the remote machine?
tgfde
Post by tgfde »
It is using the "check_nrpe" plugin. Thanks.
mguthrie
Post by mguthrie »
Sorry, I mean on the remote machine that's receiving the NRPE request. check_nrpe calls the remote agent and asks the remote machine to execute a plugin or script and return the results to the Nagios server. I need to know what it's executing on the remote machine that's giving those results, and also if it's being run on a windows machine, or unix/linux.
tgfde
Post by tgfde »
Check_logfiles
mguthrie
Post by mguthrie »
Ok, it looks like you may be getting some sort of debugging output from the plugin. The "Unknown" state is because the plugin is exiting properly and returning output that Nagios can understand. You may need to test the plugin directory on the remote machine to figure out what is causing the issue.
Here's the doc I found for that plugin, it appears to be community developed.
http://labs.consol.de/lang/en/nagios/check_logfiles/
