Product Keys
activo
Product Keys
Post by activo »
Can we find out product key from Naigios, ' of different systems connected on our network, such as Microsoft exchange licenses, or user application licenses.
Re: Product Keys
Please contact [email protected] for this information.
jolson
Attack Rabbit
Re: Product Keys
Post by jolson »
It should be in the 'license information' section.
Twits Blog
eloyd
Cool Title Here
Re: Product Keys
Post by eloyd »
I think the OP is saying "can we get the license keys or Windows, Exchange, Office, and other applications installed on a remote Windows box by using using Nagios?" Not, "can we find out the Nagios license key?"
Having said that, getting license keys is not straightforward. But you can create a script on the Windows box than can be called via Nagios (NRPE or NSclient++ or whatever you want) that runs the script and outputs the results. Look at http://www.howtogeek.com/206329/how-to- ... oduct-keys for ideas on how to get started, but it's going to be beyond the scope of this forum.
ssax
Dreams In Code
Re: Product Keys
Post by ssax »
activo, eloyd is correct, you would have to write a custom script in order to pull that information. You would then have to put that script on each of your machines for Nagios to call.
