Elasticsearch "queue capacity 1000" errors
jvestrum
Post by jvestrum »
We are trying to ingest fairly a large volume of old logs (several GB) and I'm seeing errors in the elasticsearch log:
[2015-05-28 10:00:59,818][DEBUG][action.search.type       ] [a6a1ee31-789f-4927-8680-25814f651b54] [logstash-2013.05.27][1], node[ouCBVaMVQB2IA1_D54-7dA], [P], s[STARTED]: Failed to execute [org.elasticsearch.action.search.SearchRequest@7c4b71b8] lastShard [true]
org.elasticsearch.transport.RemoteTransportException: [fd218450-44e4-4ed2-805a-74c1a72a2b63][inet[/169.10.69.98:9300]][search/phase/query]
Caused by: org.elasticsearch.common.util.concurrent.EsRejectedExecutionException: rejected execution (queue capacity 1000) on org.elasticsearch.transport.netty.MessageChannelHandler$RequestHandler@31f23aab
        at org.elasticsearch.common.util.concurrent.EsAbortPolicy.rejectedExecution(EsAbortPolicy.java:62)
        at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:821)
        at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1372)
        at org.elasticsearch.transport.netty.MessageChannelHandler.handleRequest(MessageChannelHandler.java:219)
        at org.elasticsearch.transport.netty.MessageChannelHandler.messageReceived(MessageChannelHandler.java:111)
        at org.elasticsearch.common.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:296)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:462)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:443)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303)
        at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:74)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:268)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:255)
        at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
        at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
        at org.elasticsearch.common.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
        at org.elasticsearch.common.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:745)
Searches appear to still be working correctly in the web interface, but the Administration link returns a totally blank page.
Because we are ingesting a lot of old logs that go back to 2011 and NLS creates an index for each day, we now have over 1400 indicies, so perhaps that has something to do with it.
I have plenty of disk space, only using 44GB of 1TB.
jvestrum
Re: Elasticsearch "queue capacity 1000" errors
Post by jvestrum »
So, elasticsearch is chugging through the snapshots of all those indexes:
[2015-05-28 13:07:57,037][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.12] is done
[2015-05-28 13:08:29,914][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.13] is done
[2015-05-28 13:09:33,848][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.14] is done
[2015-05-28 13:09:56,155][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.15] is done
[2015-05-28 13:10:08,375][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.16] is done
[2015-05-28 13:10:18,581][INFO ][snapshots                ] [a6a1ee31-789f-4927-8680-25814f651b54] snapshot [NagiosLogServerBackup:logstash-2013.03.17] is done
At this rate it will take a few hours to get through them all. I still can't get to the admin interface but I'll let it run and see what happens once those snapshots are done.
Let us know how this works out for you.
jvestrum
Post by jvestrum »
After the snapshots competed the "queue capacity 1000" errors stopped. However I still can't get into the Administration pages. I can log into the web interface and do searches, everything else looks okay, but as soon as I click on Administration I get a blank page. Apache is returning a 500 (Internal Server Error).
Definitely a memory limit. Edit your /etc/php.ini like so:
memory_limit = 512M
I believe it is 128M by default. Save and "service httpd restart" then visit Admin again.
jvestrum
Post by jvestrum »
Yes, that did the trick. Thanks!
jolson
Attack Rabbit
Post by jolson »
Glad to hear it! Is this case good to close?
Twits Blog
jvestrum
Post by jvestrum »
Yes, it's working fine now, it can be closed. Thanks.
