Macros missing in notifications?
jgauthier2112
Greetings everyone,
The last few days I've noticed that macros in my notifications do not seem to me expanding.
For example, here is the email I have been receiving.
***** Nagios *****
Notification Type: ACKNOWLEDGEMENT (jgu)
Host: v-itutil
State: DOWN
Address: v-itutil2
Info: kpg: Iv / - v-u2
T y
Date/Time: Thu May 28 13:35:30 EDT 2015
The host is correct. The username in the Acknowledgement is not, and the info is also completely wrong.
I typed "This is only a test" as a comment, and it shows up as "T y".
I have no changed my commands. It still looks loke this:
/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$ ($HOSTACKAUTHOR$)\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\\n$HOSTACKCOMMENT$\n\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "Host $HOSTSTATE$ alert for $HOSTNAME$!" $CONTACTEMAIL$
This seems to have just started happening in the last several days. I was running 4.0.8. I recompiled, and now is running 4.1-rc. Issue still occurs.
Any tips welcomed.
***** Nagios *****
Host: v-itutil
State: DOWN
Address: v-itutil2
T y
Any tips welcomed.
Re: Macros missing in notifications?
The only I notice about your command is that you have two slashs instead of one between the host output and host comment:
Just to verify, you are using the host notification command for the host and not the service notification command, is that correct?$HOSTOUTPUT$\\n$HOSTACKCOMMENT$
Hopefully it's not a memory issue.
Are you seeing anything strange in /var/log/messages or in your /usr/local/nagios/var/nagios.log?
jgauthier2112
Strange about the double \. I removed those. But it didn't change anything.
I can reproduce this pretty quickly. I submit the command externally like so:
echo "[`date +%s`] ACKNOWLEDGE_HOST_PROBLEM;v-itutil;2;1;0;[email protected];This is only a test" > /opt/nagios/var/rw/nagios.cmd
Then I see this in the nagios logs.
That looks good. Then the email looks like trash:
***** Nagios *****
Notification Type: ACKNOWLEDGEMENT (y)
Host: v-itutil
State: DOWN
Address: v-itutil2
T y
Date/Time: Thu May 28 16:37:31 EDT 2015
I can change my output command to a file instead of |mail, and I see the same results.
I kicked my debugging up, and took a look through the debug logs.
So, we can see it building the string here.. and it's building it completely wrong! Even from the first line:
That (y) should be [email protected].
[1432845451] EXTERNAL COMMAND: ACKNOWLEDGE_HOST_PROBLEM;v-itutil;2;1;0;[email protected];This is only a test
[1432845451] HOST NOTIFICATION: jgauthier;v-itutil;ACKNOWLEDGEMENT (DOWN);host-notify-by-email;check_ping: Invalid hostname/address - v-itutil2;[email protected];This is only a test***** Nagios *****
Host: v-itutil
State: DOWN
Address: v-itutil2
T y
[1432845793.330590] [256.1] [pid=17463] Read raw external command '[1432845793] ACKNOWLEDGE_HOST_PROBLEM;v-itutil;2;1;0;[email protected];This is only a test'
[1432845793.330615] [128.2] [pid=17463] Raw command entry: [1432845793] ACKNOWLEDGE_HOST_PROBLEM;v-itutil;2;1;0;[email protected];This is only a test
[1432845793.330727] [128.1] [pid=17463] Command Arguments: v-itutil;2;1;0;[email protected];This is only a test
[1432845793.330784] [032.0] [pid=17463] ** Host Notification Attempt ** Host: 'v-itutil', Type: ACKNOWLEDGEMENT, Options: 0, Current State: 1, Last Notification: Thu May 28 16:36:49 2015
[1432845793.332587] [2048.2] [pid=17463] Uncleaned macro. Running output (98): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil'
[1432845793.332593] [2048.2] [pid=17463] Just finished macro. Running output (98): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil'
[1432845793.332605] [2048.2] [pid=17463] Not currently in macro. Running output (107): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: '
[1432845793.332641] [2048.2] [pid=17463] Uncleaned macro. Running output (111): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN'
[1432845793.332654] [2048.2] [pid=17463] Just finished macro. Running output (111): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN'
[1432845793.332684] [2048.2] [pid=17463] Not currently in macro. Running output (122): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: '
[1432845793.332714] [2048.2] [pid=17463] Uncleaned macro. Running output (131): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2'
[1432845793.332720] [2048.2] [pid=17463] Just finished macro. Running output (131): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2'
[1432845793.332732] [2048.2] [pid=17463] Not currently in macro. Running output (139): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: '
[1432845793.332770] [2048.2] [pid=17463] Cleaned macro. Running output (155): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2'
[1432845793.332776] [2048.2] [pid=17463] Just finished macro. Running output (155): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2'
[1432845793.332794] [2048.2] [pid=17463] Not currently in macro. Running output (157): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2\n'
[1432845793.332831] [2048.2] [pid=17463] Cleaned macro. Running output (163): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2\nT y '
[1432845793.332837] [2048.2] [pid=17463] Just finished macro. Running output (163): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2\nT y '
[1432845793.332859] [2048.2] [pid=17463] Not currently in macro. Running output (180): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil\nState: DOWN\nAddress: v-itutil2\nInfo: kpg: Iv / - v-u2\nT y \n\n\nDate/Time: 'So, we can see it building the string here.. and it's building it completely wrong! Even from the first line:
[1432845793.332587] [2048.2] [pid=17463] Uncleaned macro. Running output (98): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y)\nHost: v-itutil'-
jgauthier2112
A little more from the debug log.
So there is something happening in the macro processing.
[1432847786.445135] [2048.1] [pid=32474] **** BEGIN MACRO PROCESSING ***********
[1432847786.442842] [2048.2] [pid=32474] Processing part: 'HOSTACKAUTHOR'
[1432847786.442857] [2048.2] [pid=32474] macros[49] (HOSTACKAUTHOR) match.
[1432847786.442877] [2048.2] [pid=32474] Processed 'HOSTACKAUTHOR', Free: 0
[1432847786.442891] [2048.2] [pid=32474] Processed 'HOSTACKAUTHOR', Free: 0, Cleaning options: 3
[1432847786.442907] [2048.2] [pid=32474] Cleaned macro. Running output (81): '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: ACKNOWLEDGEMENT (y
jdalrymple
- Skynet Drone
Hate to be the nay-sayer in the room, but things don't just stop working without changing something. As I read this, it happened on 4.0.8 in addition to now in 4.1-rc? Generally speaking when you have a problem going from stable --> RC is NOT the way to fix itjgauthier2112 wrote:This seems to have just started happening in the last several days. I was running 4.0.8. I recompiled, and now is running 4.1-rc. Issue still occurs.
That said let's figure out what happened.
Did you do this? If so can we see the command and the output?jgauthier2112 wrote:I can change my output command to a file instead of |mail, and I see the same results.
I might recommend that you output similar macros a few times in succession to see if the funky behavior is even reproducible.
jgauthier2112
Whoever said I didn't change anything?jdalrymple wrote:Hate to be the nay-sayer in the room, but things don't just stop working without changing something. As I read this, it happened on 4.0.8 in addition to now in 4.1-rc? Generally speaking when you have a problem going from stable --> RC is NOT the way to fix it
I went to the RC just to determine if it was a fixed bug. I was on 4.0.6, I moved to 4.0.8 after trying the RC, and it also showed the issue.
Good idea. I did. Interesting results:jdalrymple wrote:Did you do this? If so can we see the command and the output?
Ack author: (y)
Ack author: (y)
Ack author: (y)
Ack author: (y)
Host: v-itutil
State: DOWN
Address: v-itutil2
comment: T y
comment: T y
comment: T y
Date/Time: Fri May 29 09:22:40 EDT 2015I am going to spend more time today, and see if I can figure out where this is breaking down.
jgauthier2112
Well, this is disappointing.
I tracked this down to the clean_macro_chars function. This function takes the config option "illegal_macro_output_chars" and it strips this data from the string.
From my debug output, this was basically stripping ALL characters out, with the exception of a few.
I looked at stock Nagios config, and I modified my options to include only the stock Nagios.
I restarted a few times, and this did not change the issue.
So, I started adding debug code in, to confirm the contets of this variable. Mid-test, the problem went away.
I also changed debugging levels. So, thinking this triggered the event I changed the debugging levels back, but that didn't do anything.
So, I undid all my code changes for debugging, and recompiled. Everything is working now
I have no idea what triggered this to break, or what triggered it to start working. But it works now.
Ack author: ([email protected])
Host: v-itutil
State: DOWN
Address: v-itutil2
Info: check_ping: Invalid hostname/address - v-itutil2
comment: This is only a test
Date/Time: Fri May 29 13:20:44 EDT 2015-
jdalrymple
- Skynet Drone
Possible that the restarts weren't happening properly? `/etc/init.d/nagios restart`and `service nagios restart` aren't the most bulletproof methods of restarting in the world.jgauthier2112 wrote:From my debug output, this was basically stripping ALL characters out, with the exception of a few.
Aside from that the only thing I'd wonder is what you had modified that "illegal_macro_output_chars" setting to, but unless the above stated was the situation I don't know how that could have been the culprit anyway. You could try to change it back?
All that said, OK to close or do you want to try further forensic?
jgauthier2112
It was definitely restarting, because all of my custom code changes were in place.
Please don't spend any more effort on this. If it happens again, I will start up where I left off debugging the illegal macro substation.
I still wonder if was memory corruption happening from something, somewhere, somehow.
But I've lost the scenario. But i'm working again, so that is positive!
Thanks!
Thanks!
