'Apply Configuration' fails, restore of ok configs also fail
atuttle
Post by atuttle »
On both of our Nagios XI installations 'Apply Configuration' fails.
Restoring any snapshot also fails.
Nagios XI has been running fine for almost 2 years.
This is on Nagios XI Version : 2014R2.7, Red Hat Enterprise Linux Server release 6.6 2.6.32-279.5.2.el6.x86_64 x86_64.
Gnome is not installed
PHP Version: 5.3.3.
Nagios XI Data
License ends in: NSRRQO
nagios (pid 8101) is running...
NPCD running (pid 20614).
ndo2db (pid 12962) is running...
CPU Load 15: 1.13
Total Hosts: 98
Total Services: 528
Function 'get_backend_url(internal_call=true)' returns: https://localhost/nagiosxi/backend/
Re: 'Apply Configuration' fails, restore of ok configs also
Please run the following command as root from the Nagios server command line and post the results:
./reconfigure_nagios.sh | tail -20
atuttle
Post by atuttle »
--2015-05-28 11:30:09-- https://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:443... connected.
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=Washington/L=Seattle/O=UWMC-ITS/OU=DCOM-Ops/CN=its-nagios-p1/emailAddress=[email protected]”:
Self-signed certificate encountered.
WARNING: certificate common name “its-nagios-p1” doesn't match requested host name “localhost”.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
[ <=> ] 10,422 --.-K/s in 0.01s
2015-05-28 11:30:09 (688 KB/s) - “nagiosql.login” saved [10422]
2015-05-28 11:30:10 (686 KB/s) - “nagiosql.login” saved [10422]
--2015-05-28 11:30:10-- https://localhost/nagiosxi/includes/components/ccm/
Saving to: “nagiosql.export.monitoring”
[ <=> ] 13,415 24.8K/s in 0.5s
2015-05-28 11:30:11 (24.8 KB/s) - “nagiosql.export.monitoring” saved [13415]
Checked 20 time periods.
Checked 0 host escalations.
Checked 99 hosts
Checked 0 host dependencies
Checked 20 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
Running configuration check...
Stopping nagios:.. done.
Starting nagios: done.
Could you run the following in a shell on the server, Click Apply Configuration and post the output back?
fail -f /usr/local/nagiosxi/var/cmdsubsys.log
atuttle
Post by atuttle »
fail: command not found
abrist
Red Shirt
Post by abrist »
tgriep wrote:fail -f /usr/local/nagiosxi/var/cmdsubsys.log
atuttle wrote:fail: command not found
LOL.
Try:
Running the following in a shell on the server, Click Apply Configuration and post the output back:
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
atuttle
Post by atuttle »
Last change I made was yesterday when I updated component "Nagios Incident Manager" from 1.5.0 to version 2.2.0 .
I just learned I can no longer use the Admin screen to stop or restart the Monitoring Engine, Performance Grapher, and Performance Grapher.
atuttle
Post by atuttle »
PROCESSED 0 COMMANDS
AND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
xURL: https://localhost/nagiosxi/includes/components/ccm/
CMDLINE
--2015-05-28 12:25:42-- https://localhost/nagiosxi/includes/components/ccm/
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=Washington.edu”:
0K .......... 674K=0.02s
2015-05-28 12:25:42 (674 KB/s) - “nagiosql.login” saved [10422]
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=84r' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...xURL: https://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
SETUID ROOT OK
CMDLINE
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=Washington/L.edu”:
0K .......... 707K=0.01s
2015-05-28 12:25:43 (707 KB/s) - “nagiosql.login” saved [10422]
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=84rdbq' -O nagiosql.loginLOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2015-05-28 12:25:43-- https://localhost/nagiosxi/includes/components/ccm/
WARNING: cannot verify localhost’s certificate, issued by “/C=US/ST=Washington/L=Seattle/OUW.edu”:
0K .......... .. 24.7K=0.5s
2015-05-28 12:25:43 (24.7 KB/s) - “nagiosql.export.monitoring” saved [13278]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 539 services.
Checked 99 hosts.
Checked 17 host groups.
Checked 6 service groups.
Checked 15 contacts.
Checked 3 contact groups.
Checked 130 commands.
Checked 99 hosts
Total Warnings: 0
Total Errors: 0
RET: 0
sudo: no tty present and no askpass program specified
OUTPUT=RET: 0
RETURNCODE=6
PROCESSED 1 COMMANDS
tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncated
atuttle
Post by atuttle »
My sudoers has these entries:
nagios ALL=NOPASSWD:/sbin/hpasmcli
nagios ALL=NOPASSWD:/usr/bin/cciss_vol_status
nagios ALL=NOPASSWD:/opt/nagios/libexec/
nagios ALL=NOPASSWD:/usr/local/nrpe/libexec/
ssax
Dreams In Code
Post by ssax »
Please PM me your /etc/sudoers file.
Also, if you have an /etc/sudoers.d/nagiosxi file let us know.
