NSCLIENT++ and NSCA - Limit out Outplug in
Mike-sbg
Post by Mike-sbg »
I'm using Nagios Using NSCA and NSCA-NG for getting information about my windows- and "old" EL5-Linux-Server.
There is a limit of 512 bytes for sending Information in the old NSCA-Protokoll (NSCA-Server V 2.7.2)
Did anyone find out a solution that you can send longer outputs to the NSCA-Server
for example:
* NSCLIENT-Version compatible with NSCA-NG,
* a Patch for NSCA-Server allowing longer Output?
* Version of NSCA-NG for EL5?
Any sugestion would be appreciated.
Your Mike
eloyd
Cool Title Here
Re: NSCLIENT++ and NSCA - Limit out Outplug in
Post by eloyd »
Are you limited to having to use NSCA? If, instead, you could wrap your checks into an SSH-based script, you could send back arbitrarily long output strings.
jdalrymple
Skynet Drone
Post by jdalrymple »
You can either read the patch and apply it yourself (it's 4 characters in 1 line), or
tar -xzvf nrpe-2.7.2.tar.gz
patch -p0 < nsca-2.7.2_4096byte.patch
(438 Bytes) Downloaded 333 times
Mike-sbg
Post by Mike-sbg »
eloyd wrote:Are you limited to having to use NSCA? If, instead, you could wrap your checks into an SSH-based script, you could send back arbitrarily long output strings.
Yes I'm stuck to NSCA (without NG) as I'm using NSCLIENT++ for Windows and NRPE wouldn't be a solution for my problem.
I even tried NRDP which is supported by NSCLIENT++ but this causes errors,too :-(
Mike-sbg
Post by Mike-sbg »
jdalrymple wrote:You can either read the patch and apply it yourself (it's 4 characters in 1 line), or
As I read patching the size, doesn't fix the problem, because it will create errors with the checksum, or isn't that true anymore?
jdalrymple
Skynet Drone
You'll have to use the patched send_nsca also and then it should work fine. For nsclient++ it's just a config option.
I'm using this code in production.
Mike-sbg
Post by Mike-sbg »
Thank you all for the help!!! :D
As suggested I patched den NSCA Command (Server and Client) and modified die Config in the NSClient++ and everything works fine.
One last tip for other reading this thread: When you patch the Parameter: MAX_PLUGINOUTPUT_LENGTH it is also necessary to patch the MAX_INPUT_BUFFER. If you miss this patch, the Data will be transported and accepted by the CRCCheck, but I will be truncated at the length of the MAX_INPUT_BUFFER
I'll be closing this thread now, but feel free to open another if you need anything in the future!
