Bad import file
CFT6Server
Bad import file
During the import configuration file process, there was a bad configuration file. Is there any way to reverse this? or remove the bad config so when we click on Apply Configuration, it doesn't try to apply the config?
Re: Bad import file
Prior to applying configuration, you will need to run the Write Config Tool, in order to make sure you don't have any config errors.
CFT6Server
Re: Bad import file
Hi Yes, I am at that stage, but now it seems the configuration is stuck. So how do I reverse this and get rid of what's imported??
Re: Bad import file
Your best bet is to do one of the following:
1. Remove the broken objects by hand in the ccm (can be tedious depending on how many were added in the batch with the bad configs).
2. Revert the snapshot for the ccm. (admin --> config snapshots)
