NagMap for Nagios Core 4.0.7
gvalgz
Post by gvalgz »
Hi Everyone,
Would NagMap work with the Nagios Core v4.0.7?
Also, the source file link is no longer available. Can you provide me with a link?
Hope anyone could help me.
Regards!
Gvalgz
Note: I had to remove the link you posted and edit your question.
Re: NagMap for Nagios Core 4.0.7
NagMap is a 3rd party product. We haven't tested it, so I am not sure if it will work with Nagios Core 4.0.7. If you decide to try it and run into some issues, please let us know. We will try to help you out.
I found a link to "nagmap-1.0.tar.gz" on GitHub:
https://github.com/hecko/nagmap/downloads
Hope this helps. Thanks!
