Starts with
Starts with
How would I make a filter for a query in NLS for all fields starting with "bla"?
Nagios XI 5.8.1
https://outsideit.net
Re: Starts with
Navigate to the Dashboard and open up the query you want to start with e.g. last 7 days with a '*' query.
After you have your dashboard ready, select any field on your table and press the action button next to the field. After making that selection, a new filter will appear. This new filter has globbing support. Let me know if the above works for you.
