objects.cache showing wrong information? (Or not up to date)
WillemDH
Post by WillemDH »
Just noticed something. When I cat the objects.cahe file for (for example) my Reactor server;
cat /usr/local/nagios/var/objects.cache | sed -rn "/define host \{/{:a;N;/}/{/.host_name.reactor01/p;d};ba}"
define host {
        host_name      reactor01
        alias   reactor01
        address xx.xx.xx.xx
        check_period    xi_timeperiod_24x7
        check_command   check_xi_host_ping!3000.0!80%!5000.0!100%!!!!
        contacts        nagiosadmin,contactfts,nagiosadmin
        contact_groups  xi_dig_dummy_contact_group
        notification_period     xi_timeperiod_24x7
        initial_state   o
        importance      0
        check_interval  5.000000
        retry_interval  1.000000
        max_check_attempts      3
        active_checks_enabled   1
        passive_checks_enabled  1
        obsess  1
        event_handler_enabled   1
        low_flap_threshold      0.000000
        high_flap_threshold     0.000000
        flap_detection_enabled  1
        flap_detection_options  a
        freshness_threshold     0
        check_freshness 0
        notification_options    a
        notifications_enabled   1
        notification_interval   1440.000000
        first_notification_delay        0.000000
        stalking_options        n
        process_perf_data       1
        retain_status_information       1
        retain_nonstatus_information    1
        _XIWIZARD       windowsserver
I see several things that are not correct and not synchrone with the actual config:
_XIWIZARD windowsserver => Ther is no free variable defined for this host...
contacts nagiosadmin,contactfts,nagiosadmin => I deleted the contact fts a few weeks ago...
When I read http://sites.box293.com/nagios/guides/t ... ng-objects the objects.cache should contain the final object after all templates have been taken into account.
So why is it showing wrong config for this host object?
define host {
        host_name                       reactor01
        use                             dig_linux_server_prio2
        alias                           reactor01
        address                         xx.xx.xx.xx
        hostgroups                      +hg_inf_vir_vmw,hg_loc_dg,hg_os_linux_centos,hg_rol_monitoring
        contacts                        +nagiosadmin
        contact_groups                  +xi_dig_dummy_contact_group
        register                        1
This is the template:
define host {
       name                                     dig_linux_server_prio2
       alias                                    dig_linux_server_prio2
       check_interval                           5
       retry_interval                           1
       process_perf_data                        1
       register                                 0
Nagios XI 5.8.1
https://outsideit.net
jdalrymple
Skynet Drone
Re: objects.cache showing wrong information? (Or not up to d
Post by jdalrymple »
WillemDH wrote:So why is it showing wrong config for this host object?
Because your Nagios is broken maybe?
ls -l /usr/local/nagios/var/objects.cache
should coincide with your last reload
[jdalrymple@localhost ~]$ ls -l /usr/local/nagios/var/objects.cache
-rw-r--r--. 1 nagios nagios 45643 Jun  2 14:41 /usr/local/nagios/var/objects.cache
[jdalrymple@localhost ~]$ sudo /etc/init.d/nagios reload
[sudo] password for jdalrymple:
Reloading nagios configuration (via systemctl):            [  OK  ]
-rw-r--r--. 1 nagios nagios 45643 Jun  4 09:27 /usr/local/nagios/var/objects.cache
[jdalrymple@localhost ~]$ date
Thu Jun  4 09:27:15 CDT 2015
What does the configuration in the core interface say:
Configuration --> Services
Find your service - look in the Default Contacts/Groups column
WillemDH
Post by WillemDH »
Hmmm,
Very weird:
-rw-r--r--. 1 nagios nagios 9953257 Apr 13 13:08 /usr/local/nagios/var/objects.cache
13/04?? Does this mean it had no updates since 13/04?
Running configuration check...
Reloading nagios configuration...
done
 date
Thu Jun  4 16:38:28 CEST 2015
The example I gave was from a host.. In CMM everything is 'like we configured it'.
Please advise how to fix my broken Nagios. I've been seeing some weird stuff lately. Might be related. I rebooted my server today, but the objects.cache is still not updating. :(
Grtz
Willem
Nagios XI 5.8.1
jdalrymple
Skynet Drone
If you do a full /etc/init.d/nagios restart then peek at nagios.log at the "relevant time" do you see anything alarming?
[1433429092] ndomod: Shutdown complete.
[1433429092] Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
[1433429093] Nagios 4.0.8 starting... (PID=104749)
[1433429093] Local time is Thu Jun 04 09:44:53 CDT 2015
[1433429093] LOG VERSION: 2.0
[1433429093] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized...
WillemDH
Post by WillemDH »
Ok, forgive me... Just remembered I configured a ramdisk 13/04... I was catting the wrong objects.cache. :oops:
cat /var/nagiosramdisk/objects.cache | sed -rn "/define host \{/{:a;N;/}/{/.host_name.srvreactor01/p;d};ba}"
define host {
        host_name       reactor01
        alias   reactor01
        address xx.xx.xx.xx
        contacts        nagiosadmin,nagiosadmin
        initial_state   o
        importance      0
        obsess  1
        check_freshness 0
        stalking_options        n
        process_perf_data       1
This one does contain the correct info... Please permanently delete this thread. :D
Nagios XI 5.8.1
ssax
Dreams In Code
Post by ssax »
I'm glad you got that sorted, marking as resolved and locking.
