Nagios problems on Debian after dist-upgrade
molla
Post by molla »
Dear All.
I have done an OS dist-upgrade to Debian Wheezy, my nagios core version was on 3.2.1, and now it has upgraded to version 3.4.1, and it is throwing all sorts of errors. One baffling one is below. Please help me someone.
Warning: Duplicate definition found for contact 'sysadmin' (config file '/etc/nagios3/conf.d/contacts.cfg', starting on line 5)
Error: Could not add object property in file '/etc/nagios3/conf.d/contacts.cfg' on line 6.
errors in config! ... failed!
failed!
Would very much appreciate some help. Thank you.
Re: Nagios problems on Debian after dist-upgrade
Could you post the file that is causing the errors so we can review it? Please upload the following file.
