For Example> Disk checking is configured Drive c through k. If the server has any of those drives they will be checked. If the server does not have some of those drives then the check is ignored.
In Nagios it appears that if the server does not have a drive or a service that is identified as a check then an UNKNOWN status appears vs. to simply not check or report.
I would like to know either A) Can nagios be configured to do smart checking whereby if a drive or service does not exist then don't check or report on it. And having said that I don't want to have to go into each server and manually set this.
B) Can I at least change the color of the UNKNOWN status to something other than alarming Orange.... and how is this done (easily accomplished)
Thanks in advance
