New to the nagios log i followed the directions and did this
curl -s -O http://10.1.1.154/nagioslogserver/scrip ... p-linux.sh
bash setup-linux.sh -s 10.1.1.154 -p 5544
created a dash board but i get no output.
It worked 1st time i did it but after adding a server to monitor i get no output.
No output.
Re: No output.
When you ran the above commands, did you get any output? Error messages or success messages could be useful.curl -s -O http://10.1.1.154/nagioslogserver/scrip ... p-linux.sh
Please run the following on your client node:
cat /etc/rsyslog.conf
cat /etc/rsyslog.d/*.confRe: No output.
# rsyslog v5 configuration file
# For more information see /usr/share/doc/rsyslog-*/rsyslog_conf.html
# If you experience problems, see http://www.rsyslog.com/doc/troubleshoot.html
#### MODULES ####
$ModLoad imuxsock # provides support for local system logging (e.g. via logger command)
$ModLoad imklog # provides kernel logging support (previously done by rklogd)
#$ModLoad immark # provides --MARK-- message capability
# Provides UDP syslog reception
#$ModLoad imudp
#$UDPServerRun 514
# Provides TCP syslog reception
#$ModLoad imtcp
#$InputTCPServerRun 514
#### GLOBAL DIRECTIVES ####
# Use default timestamp format
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
# File syncing capability is disabled by default. This feature is usually not required,
# not useful and an extreme performance hit
#$ActionFileEnableSync on
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
#### RULES ####
# Log all kernel messages to the console.
# Logging much else clutters up the screen.
#kern.* /dev/console
# Log anything (except mail) of level info or higher.
# Don't log private authentication messages!
*.info;mail.none;authpriv.none;cron.none /var/log/messages
# The authpriv file has restricted access.
authpriv.* /var/log/secure
# Log all the mail messages in one place.
mail.* -/var/log/maillog
# Log cron stuff
cron.* /var/log/cron
# Everybody gets emergency messages
*.emerg *
# Save news errors of level crit and higher in a special file.
uucp,news.crit /var/log/spooler
# Save boot messages also to boot.log
local7.* /var/log/boot.log
# ### begin forwarding rule ###
# The statement between the begin ... end define a SINGLE forwarding
# rule. They belong together, do NOT split them. If you create multiple
# forwarding rules, duplicate the whole block!
# Remote Logging (we use TCP for reliable delivery)
# An on-disk queue is created for this action. If the remote host is
# down, messages are spooled to disk and sent when it is up again.
#$WorkDirectory /var/lib/rsyslog # where to place spool files
#$ActionQueueFileName fwdRule1 # unique name prefix for spool files
#$ActionQueueMaxDiskSpace 1g # 1gb space limit (use as much as possible)
#$ActionQueueSaveOnShutdown on # save messages to disk on shutdown
#$ActionQueueType LinkedList # run asynchronously
#$ActionResumeRetryCount -1 # infinite retries if host is down
# remote host is: name/ip:port, e.g. 192.168.0.1:514, port optional
#*.* @@remote-host:514
# ### end of the forwarding rule ###
#### MODULES ####
#$ModLoad imudp
#$UDPServerRun 514
#$ModLoad imtcp
#### RULES ####
# Log cron stuff
*.emerg *
Re: No output.
# NAGIOS LOG SERVER
*.* @@localhost:5544
# NAGIOS LOG SERVER
Re: No output.
It looks like you ran the commands that I specified on your Nagios Log Server instance - please run the commands on your remote client instead.
Re: No output.
#### MODULES ####
$ModLoad imuxsock # provides support for local system logging (e.g. via logger c ommand)
#$ModLoad imudp
#$UDPServerRun 514
#$ModLoad imtcp
# File syncing capability is disabled by default. This feature is usually not re quired,
#### RULES ####
# Log cron stuff
*.emerg *
#### MODULES ####
#$ModLoad imudp
#$UDPServerRun 514
#$ModLoad imtcp
#### RULES ####
# Log cron stuff
*.emerg *
Re: No output.
### Begin forwarding rule for Nagios Log Server NAGIOSLOGSERVER
$WorkDirectory /var/lib/rsyslog # Where spool files will live NAGIOSLOGSERVER
$ActionQueueFileName nlsFwdRule0 # Unique name prefix for spool files NAGIOSLOGSERVER
$ActionQueueMaxDiskSpace 1g # 1GB space limit (use as much as possible) NAGIOSLOGSERVER
$ActionQueueSaveOnShutdown on # Save messages to disk on shutdown NAGIOSLOGSERVER
$ActionQueueType LinkedList # Use asynchronous processing NAGIOSLOGSERVER
$ActionResumeRetryCount -1 # Infinite retries if host is down NAGIOSLOGSERVER
# Remote host is: name/ip:port, e.g. 192.168.0.1:514, port optional NAGIOSLOGSERVER
*.* @@10.1.1.154:5544 # NAGIOSLOGSERVER
### End of Nagios Log Server forwarding rule NAGIOSLOGSERVER
Re: No output.
Got it to work.
I had to do it manually i don't know why the script didn't work.
Re: No output.
Thanks for reporting back! Could you elaborate on what you mean by having to do it manually? As far as I can tell, the configurations you have posted look alright.
Re: No output.
/var/lib/rsyslog suppose to be /var/sloop/rsyslog
