Dear Community,
first off all i wanna say that i'm an newbie at Nagios.
I got problems with Check_Disk at NRPE.
I wanna check the Space of /dev/sda1
with check_disk -w 85% -c 90% -p /dev/sda1
But i get response
Linux_Festplattenspeicher KRITISCH 0 Tage, 5 Stunden, 26 Minuten DISK CRITICAL - free space: /dev 10 MB (100% inode=99%):
Hopefully someone can help me , if you need more information just ask for
Greetings JAL
Problems with Check_Disk
jdalrymple
- Skynet Drone
Re: Problems with Check_Disk
I'm assuming that you're confused by the thresholds:
I think you probably want:
Does that make based upon the usage?
-w, --warning=INTEGER
Exit with WARNING status if less than INTEGER units of disk are free
-w, --warning=PERCENT%
Exit with WARNING status if less than PERCENT of disk space is free
-c, --critical=INTEGER
Exit with CRITICAL status if less than INTEGER units of disk are free
-c, --critical=PERCENT%
Exit with CRITICAL status if less than PERCENT of disk space is freeCode: Select all
check_disk -w 15% -c 10% -p /dev/sda1Re: Problems with Check_Disk
Ok, thx this fixed one of my problems
But i want to check the disk /dev/sda1 with ~10 GB, but it seems for me that it checks /dev with only 10 MB !?
Then you can pass the "unit" flag to specify "GB" (- u), for example:
./check_disk -u GB -w 15 -c 10 -p /dev/sda1You can review the plugin's usage by running:-u, --units=STRING
Choose bytes, kB, MB, GB, TB (default: MB)
./check_disk -hBe sure to check out our Knowledgebase for helpful articles and solutions!
