I've disabled http on our Nagios server so the only way to access the interface is via https. I've used the instructions found online (http://communitygrids.blogspot.com/2010 ... oring.html) to create a check for https. The service shows up under the host, but it indicates a warning because of the 403 Forbidden code returned due to shutting down http.
I'm certain it is failing on http and not https due to the status message: HTTP WARNING: HTTP/1.1 403 Forbidden - 4183 bytes in 0.009 second response time
I don't even have http defined as a service in the localhost.cfg file anymore since moving it to https.
How can I disable checks on http and only check https?
Check https but not http
Re: Check https but not http
The entry in command.cfg:
and the server in localhost.cfg:
# 'check_https' command definition
command_name check_https
command_line $USER1$/check_http -I $ARG1$ -S
# command_line $USER1$/check_http -I $HOSTADDRESS$ -p $ARG1$ -S
}Code: Select all
use local-service ; Name of service template to use
host_name tcecapmgr5ng01
service_description HTTPS
check_command check_https!10.153.106.250
notifications_enabled 0
