Operation Screen - Play Sound
derekb
Post by derekb »
Is it possible to modify the php for the Operation Screen to play a sound file (.wav) when a down host is detected?
ssax
Dreams In Code
Re: Operation Screen - Play Sound
Post by ssax »
Should be doable, are you requesting any critical (host and service) or just if a host is down?
derekb
Post by derekb »
Well, I imagine the php/HTML code is extremely similar for both. My preference is just for critical hosts at the moment.
ssax
Dreams In Code
Post by ssax »
I can point you in the right direction but it will get reverted if/when you do an upgrade and it's not something that we support.
Edit /usr/local/nagiosxi/html/includes/components/opscreen/opscreen.php and add this under the <script type="text/javascript"> section:
    function play_sound() {
        var audioElement = document.createElement('audio');
        audioElement.setAttribute('src', 'http://www.stephaniequinn.com/Music/Allegro%20from%20Duet%20in%20C%20Major.mp3');
        audioElement.setAttribute('autoplay', 'autoplay');
        audioElement.load();
        audioElement.play();
Edit /usr/local/nagiosxi/html/includes/components/opscreen/merlin.php
Find this code:
$hosts_down = $row[0];
Add this code right beneath it:
        $file = '/tmp/hosts_down_temp.txt';
        // Add host count to file
        // Open the file to get existing content
        $old_hosts_down = file_get_contents($file);
        // Write the new host down count to the file
        file_put_contents($file, $hosts_down);
        if ($old_hosts_down < $hosts_down) {
                echo '<script type="text/javascript">play_sound();</script>';
That should get you going in the right direction, works for me, you may modify it to your liking.
derekb
Post by derekb »
Awesome!
I'll give it a shot and report back with my results. Thank you very very much
ssax
Dreams In Code
Post by ssax »
You could also just copy your mp3 file to /usr/local/nagiosxi/html/images
chmod 640 /usr/local/nagiosxi/html/images/alarm.mp3
chown nagios.nagios /usr/local/nagiosxi/html/images/alarm.mp3
Then you could change the code to:
        audioElement.setAttribute('src', '/nagiosxi/images/alarm.mp3');
