Question about logwatch
michaelli
Post by michaelli »
I find out check_mk use logwatch for log messages monitor. It can full display error messages history until clear manually. So I think this program are better than check_logfiles. Therefore is it possible to configure in nagosxi?
Re: Question about logwatch
It certainly should be. How would you run the command from the command line? That is essentially what you would want to enter in as a command in XI according to the following doc:
