Cannot remove "winserver" from Host Detail
Cyber Saiyan
Post by Cyber Saiyan »
I am having an issue after installing Core 4 on Ubuntu 15.x.
I followed the install guide by Unixmen (http://www.unixmen.com/install-configur ... 4-1014-04/). I have all of my windows server config files under the /usr/local/nagios/etc/objects, each in their own CFG file; and added the path of each CFG file to /usr/local/nagios/etc/nagios.cfg; everything is working great.
The issue I have is that I have one extra server named winserv hanging out in my server list on the Host Detail page. I know where it is coming from, but I cannot figure out how to remove it. This is coming from the windows.cfg file inside the objects folder where all my other config files are, but if I remove this file and remove the line entry from nagios.cfg, the nagios service fails to start up. Here is the contents of the file:
use windows-server ; Inherit default values from a template
host_name winserver ; The name we're giving to this host
alias My Windows Server ; A longer name associated with the host
address xxx.xxx.xxx.xxx ; IP address of the host
define hostgroup{
hostgroup_name windows-servers ; The name of the hostgroup
alias Windows Servers ; Long name of the group
host_name winserver
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
I have commented out everything that I can without the service crashing, but I cannot get this machine off the monitoring page. I don't want to monitor the NSClient++ service, nor do I even want this machine on the monitoring page. Here is the verbose output from the sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg test:
Nagios Core 4.1.0rc1
Last Modified: 02-18-2015
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid max_check_attempts value for host 'xxxxxxxxx'
Error: Could not register host (config file '/usr/local/nagios/etc/objects/xxxxxxxxxx.cfg', starting on line 4)
administrator@Nagios:/usr/local/nagios/etc/objects$
I think this windows.cfg file is a template for other parts of Nagios Core 4 but I am not sure. How can I remove this entry?
Re: Cannot remove "winserver" from Host Detail
The file that is causing the error is missing the setting for
 max_check_attempts
You can either set that up manually or add a template to that host/service that has the max_check_attempts defined.
Cyber Saiyan
max_check_attempts is defined in the TEMPLATES.CFG file, which is uncommented in NAGIOS.CFG:
Nagios.cfg:
cfg_file=/usr/local/nagios/etc/objects/commands.cfg
cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/objects/templates.cfg
Templates.cfg:
name windows-server ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_period 24x7 ; By default, Windows servers are monitored round the clock
check_interval 5 ; Actively check the server every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each server 10 times (max)
check_command check-host-alive ; Default command to check if servers are "alive"
notification_period 24x7 ; Send notification out at any time - day or night
notification_interval 30 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
hostgroups windows-servers ; Host groups that Windows servers should be a member of
register 0 ; DONT REGISTER THIS - ITS JUST A TEMPLATE
I tried to add it in to the individual server's config file:
host_name (I REMOVED THIS) ; The name we're giving to this host
address (I REMOVED THIS) ; IP address of the host
This did not work either............
ssax
Dreams In Code
Post by ssax »
If adding it to the individual server's config file didn't work, it must be defined elsewhere, check with this command:
grep -R "YOUR_SERVER_NAME" /usr/local/nagios/etc
Cyber Saiyan
The only results when grepping for the sever name is the SERVERNAME.cfg file inside of /usr/local/nagios/etc/objects
There are a few .SAVE files as backups but nothing other than that.
I also grepped for max_check_attempts and it is defined in the templates.cfg file (like I THINK it should be).
administrator@Nagios:/usr/local/nagios/etc$ sudo grep -R "max_check_attempts" /usr/local/nagios/etc
/usr/local/nagios/etc/servers/client.cfg: max_check_attempts 5
/usr/local/nagios/etc/servers/client.cfg.save:max_check_attempts 5
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 10 ; Check each Linux host 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 10 ; Check each server 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 10 ; Check each printer 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 10 ; Check each switch 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
/usr/local/nagios/etc/objects/templates.cfg~: max_check_attempts 4 ; Re-check the service up to 4 times in order to determine its final (hard) state
/usr/local/nagios/etc/objects/xxxxxxxxx.cfg: max_check_attempts 10 ; Check each server 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg: max_check_attempts 10 ; Check each Linux host 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg:# max_check_attempts 10 ; Check each server 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg: max_check_attempts 10 ; Check each printer 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg: max_check_attempts 10 ; Check each switch 10 times (max)
/usr/local/nagios/etc/objects/templates.cfg: max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
/usr/local/nagios/etc/objects/templates.cfg: max_check_attempts 4 ; Re-check the service up to 4 times in order to determine its final (hard) state
/usr/local/nagios/etc/objects/xxxxx_orig.cfg: max_check_attempts 10 ; Check each server 10 times (max)
Is there any way to simply start the nagios service successfully without the windows.cfg line inside of /usr/local/nagios/etc/nagios.cfg file?
ssax
Dreams In Code
Post by ssax »
Please zip up your /usr/local/nagios/etc directory and PM it to me, I will look it over and find the solution for you.
ssax
Dreams In Code
Post by ssax »
Also, yes you can edit your /usr/local/nagios/etc/nagios.cfg and change:
cfg_file=/usr/local/nagios/etc/objects/windows.cfg
To:
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
Then it won't process that file.
Cyber Saiyan
I have tried that already but the Nagios service fails to start with that specific line commented out. I will try again in the morning and post the verbose output from the logs.
Thanks for the continued effort.
Run the following command and show us the output:
Note: Modify this command if paths are different on your system.
As ssax said, you can zip up your /usr/local/nagios/etc directory and PM it to any of us (on the Nagios support tech team). Thanks!
Cyber Saiyan
lmiltchev has reviewed the dir structure and did not get any errors during startup as is. The config included on that specific settings does not give me any issues either, but when I comment out the windows.cfg line inside of nagios.cfg is where it complains. I have an additional "winserv" machine hanging out on my host page that comes from the windows.cfg file.
I guess that I can remove one of the machines config file (domaincontroller.cfg) and use the windows.cfg file to monitor that specific machine to get rid of the "winserv" machine, but don't like that all machines have their own config files except for this one.
Unless someone can find a solution for me in the next day or two, I don't think its worth keeping open for a simple annoyance on my end.
