How to check amount of connections on remote port
intern_nagios
Post by intern_nagios »
Hi there,
Do you know if there is an way to check the amount of connections on a remote host/port? Let's say I want to know how many connections on port 1723 (VPN) on "server x" are active?
I tried a couple of "check connections" plugins on the Nagios Exchange but I can't make them check an remote host.
Thanks.
eloyd
Cool Title Here
Re: How to check amount of connections on remote port
Post by eloyd »
You need to use an agent on the remote host to run the check and return results back to Nagios, or else use passive checks. Google for NRPE, or wrap checks in the check_by_ssh wrapper, or Google for Nagios passive checks.
jolson
Attack Rabbit
Post by jolson »
To supplement eloyds post,
Download NRPE: https://exchange.nagios.org/directory/A ... or/details
Official NRPE documentation: http://nagios.sourceforge.net/docs/nrpe/NRPE.pdf
Passive Checks: http://nagios.sourceforge.net/docs/3_0/ ... hecks.html
Let us know if you have any questions!
Twits Blog
eloyd
Cool Title Here
Post by eloyd »
Sorry for my terseness. Was writing from smartphone. :)
abrist
Red Shirt
Post by abrist »
@eloyd: terse, but correct nonetheless :)
@OP: eloyd is correct, you need to run the connections check from the remote host in order to collect the desired info.
intern_nagios
Thanks guys.
I use the plugin "check_connections.sh" to count the amount of connections on a to be determined port. The command to run the plugin is specified as following:
        command_name    check_vpn_connections
        command_line    $USER1$/check_connections.sh -s all '( dport = :1723 )' -w 200 -c 300
In NRPE.cfg, I specified the following:
command[check_vpn_connections]=/usr/lib64/nagios/plugins/check_connections.sh -s all '( dport = :1723 )' -w $ARG1$ -c $ARG2$
Something strange, is that the first 3 lines are yellow and red, but my line for the conncetions stays red.
command[check_dell_alertlog]=/usr/lib64/nagios/plugins/check_openmanage –only alertlog
command[check_dell_critical]=/usr/lib64/nagios/plugins/check_openmanage –only critical
command[check_dell_warning]=/usr/lib64/nagios/plugins/check_openmanage –only warning
Afterwards, I restarted the NRPE service
The output is as following:
[root@xxx plugins]# ./check_nrpe -H xxxx -c check_vpn_connections -a 20 30
NRPE: Command 'check_vpn_connections' not defined
I guess the color indicates I'm doing something wrong, as the output says the same. Does anyone have a clue?
The color itself is just syntax highlighting, but you're right in that it does look weird. NRPE is probably seeing that "dport =" part and hanging on that.
Can you try to modify the check_connections.sh script to hard-code in the -s all '( dport = :1723 )' part? That might be the easiest way short of patching NRPE (which would take a while).
intern_nagios
I'm using an other plug-in now, that's not great but it should do the work. Thanks for cooperating.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
