Downtime, HistoryTab.zip
bbailey6
Post by bbailey6 »
Is historytab.zip the only way to see downtime you previously scheduled? I had a host that came out of a flexible downtime window about 12 hours later than scheduled. I was looking for a way to see what I set. I was scheduling a lot of downtime last week and I am sure I fat fingered it but I wanted to know for sure.
p.s. I can't download the historytab.zip from the nagios exchange. Cannot open or open after saving as on Windows 7.
Ben
Re: Downtime, HistoryTab.zip
You can look in the nagios.log for info on scheduled downtime:
cat /usr/local/nagios/var/nagios.log | perl -pe 's/(\d+)/localtime($1)/e' | grep SCHEDULE_HOST_DOWNTIME
You don't need to open/extract the historytab.zip. You need to download it, and install the component by going to:
Admin->Manage Components->Browse->historytab.zip->Upload Component
bbailey6
Post by bbailey6 »
hi lmiltchev,
Ah ok. So only way to see what you've done is either catting through the logs or the historytab? Nothing through the GUI?
abrist
Red Shirt
Post by abrist »
The Event Log in Nagios XI should show scheduled downtime history - just search for "downtime".
