check_tcp plugin not working
Amit585731
Post by Amit585731 »
All,
I am trying to monitor a tcp service (port 9100) on remote host but on nagios GUI host showing status pending. Any suggestion?
Below is the config I am using for same:
define hostgroup{
hostgroup_name Server
alias Server Check
members server5220
use generic-host
host_name server5220
alias Print Server
address 1.1.1.1
max_check_attempts 5
; monitoring tcp service
use generic-service ; Inherit values from a template
; hostgroup_name Server; The name of the host the service is associated with
service_description TCP Check ; The service description
check_command check_tcp!9100 ; The command used to monitor the service
normal_check_interval 5 ; Check the service every 5 minutes under normal conditions
retry_check_interval 1 ; Re-check the service every minute until its final/hard state is determined
abrist
Red Shirt
Re: check_tcp plugin not working
Post by abrist »
Does it have a next check time? If so, does that value keep getting bumped out?
Also, what version of core are you running?
If you are running core 4, can you post the output of:
grep "auto_" /usr/local/nagios/etc/nagios.cfg
Amit585731
host check attempt is 5 min. and I am using nagios 3.3.1
Post by Box293 »
Have a look in /usr/local/nagios/var/objects.cache and find the service. Post that here.
Amit585731
Abrist,
Here is the output I am seeing
auto_reschedule_checks=0
# has an effect if the auto_reschedule_checks option is enabled.
auto_rescheduling_interval=30
# only has an effect if the auto_reschedule_checks option is
auto_rescheduling_window=180
Amit585731
Box293,
Here is the output I am seeing:
Also in nagios GUI I am seeing services as 'No matching services'.
command_name check_tcp
command_line $USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
alias Server Check
address 1.1.1.1
notification_period 24x7
initial_state o
check_interval 5.000000
retry_interval 1.000000
max_check_attempts 2
active_checks_enabled 1
passive_checks_enabled 1
obsess_over_host 1
event_handler_enabled 1
low_flap_threshold 0.000000
high_flap_threshold 0.000000
flap_detection_enabled 1
flap_detection_options o,d,u
freshness_threshold 0
check_freshness 0
notification_options d,u,r,f,s
notifications_enabled 1
notification_interval 30.000000
first_notification_delay 0.000000
stalking_options n
process_perf_data 1
failure_prediction_enabled 1
retain_status_information 1
Can you show us a screen shot of this?
Also, it looks like you posted the host check instead of the service check from the objects.cache file. Can you post the service check again?
