Nagios process not running on server ...
jyoti22
Post by jyoti22 »
Hi Team
I am currently using evaluation license for nagios POC setup. My evaluation license got expired on 9th June and extended same for one month on next day.
Before license expiration nagios was working fine. But from that date, nagios is not working and I am not able to start nagios process on the server. Can you please guide me on this as I do not want to reinstall nagios xi server.
In admin -> system profile I get below output
License ends in:
Days left in Trial: 24
nagios is not running
NPCD running (pid 6245).
ndo2db (pid 6388) is running...
CPU Load 15: 0.36
Total Hosts: 19
Total Services: 114
Please help on this issue
Re: Nagios process not running on server ...
Please run the following command as root from the Nagios server command line and post the results:
jyoti22
Post by jyoti22 »
Thanks for quick reply. Here is the output.
Nagios Core 4.0.8
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo rs
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 114 services.
Checked 19 hosts.
Checked 5 host groups.
Checked 3 service groups.
Checked 10 contacts.
Checked 5 contact groups.
Checked 163 commands.
Checked 16 time periods.
Checked 0 host escalations.
Checked 19 hosts
Checked 0 host dependencies
Checked 16 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Post by Box293 »
what happens if you run:
service nagios start
on the command line?
jyoti22
Post by jyoti22 »
[root@nagiosxi ~]# service nagios start
Starting nagios: done.
[root@nagiosxi ~]# service nagios stop
Stopping nagios:/etc/init.d/nagios: line 141: kill: (27041) - No such process
done.
[root@nagiosxi ~]#
ssax
Dreams In Code
Post by ssax »
Run the commands below and post the full output in code tags:
service nagios stop
ps -aux | grep nagios
jyoti22
Post by jyoti22 »
Please find output of the commands in attached file
It looks like there is a stuck Nagios process. Try running this set of commands to see if it starts for you.
service nagios stop
killall nagios
Let us know if this resolves the issue.
jyoti22
Post by jyoti22 »
Thank You tgriep for reply. I already ran the commands but no help.
jyoti22
Post by jyoti22 »
Please find attached nagios.debug file for reference.
