problem with the "&" symbol in the tool tab
pamuro01
Post by pamuro01 »
Each time you add a url in the "Tool" tab which contains the "&" symbol, the text "amp;" It is added by itself.
This makes the link is wrong and does not work the tool.
As you can solve?
Re: problem with the "&" symbol in the tool tab
What XI version are you running? It works fine in the latest developer revision so it seems to have been fixed.
pamuro01
Post by pamuro01 »
I used the last versión
Nagios XI 2014R2.7
Does the text "amp" show up before you save the URL or after you save it.
What Web browser and version are you using?
Have you tried other browsers and are they giving you the same results?
