received the error below for all the services after set up a host to monitor a MS SQL server 2008 by using the wizard. It was working fine when I tested it from the VM NagiosXI. Any ideas about it? thanks.
(No output on stdout) stderr: /bin/sh: -c: line 0: unexpected EOF while looking for matching `''
/bin/sh: -c: line 1: syntax error: unexpected end of file
SQL Server Error
Re: SQL Server Error
What is the version of the Nagios XI and the MSSQL Server wizard that you are currently using?
Admin->Manage Config Wizards
Can you show us one of the failing checks, run from the command line, along with the output of it?
Also, run the following command and show us the output:
head -25 /usr/local/nagios/libexec/check_mssql_server.pyBe sure to check out our Knowledgebase for helpful articles and solutions!
Thank you for the quick response.
We used the latest version NagiosXI offline mode.
MS SQL Server Version: 1.8.5
Below shows the output from the command.
==> standard input <==
Did you forget to show us the output?Below shows the output from the command.
head -25 /usr/local/nagios/libexec/check_mssql_server.pyCode: Select all
/usr/local/nagios/libexec/check_mssql_server.py -H x.x.x.x -U 'username' -P 'password' -I 'INSTANCE' --averagewait --warning 2000 --critical 3000
OK: Average Wait Time (ms) is 1195.70149254ms|averagewait=1195.70149254ms;2000;3000;;Be sure to check out our Knowledgebase for helpful articles and solutions!
Thanks for your help!
I followed your steps, I think the error was caused by the password contains a special char "!". Thanks for your time again.
I am glad your issue has been resolved! I am locking this topic.
