problems check_ms_windows_disk_load plugin
pkarr
Post by pkarr »
I'm trying to get the check_ms_windows_disk_load plugin from the Nagios Exchange to work
(https://exchange.nagios.org/directory/P ... ad/details)
I saw the recent post on it and tried the suggestions but to no avail. Note that I have other nsclient/check_nrpe service checks running successfully on this server.
Here is my command definition from the NSC.ini configuration (we are using NSClient 0.3.9) on the remote server
check_ms_diskload=cmd /c echo scripts\check_ms_windows_disk_load.ps1 $ARG1$; exit $LastExitCode | powershell.exe -command -
and here is from the command line on my Nagios server
[root@lkennagiost02 libexec]# ./check_nrpe -H 172.22.2.133 -p 5666 -t 60 -c check_ms_diskload -a '-ms 5 -dl'
Unknown: Illegal arguments detected.
Any ideas as to what's wrong?
Penny Karr | IT Infrastructure Monitoring
Harvard Vanguard Medical Associates, an Affiliate of Atrius Health
254 Second Avenue | Needham, MA 02494
P (781) 292-1853 | F (781 292-1980 | http://www.harvardvanguard.org
Email: [email protected]
Re: problems check_ms_windows_disk_load plugin
Have you tried to run the script locally on the Windows box to see if it is going to work with these arguments?
You can try wrapping the $ARG1$ in double quotes, i.e.
check_ms_diskload=cmd /c echo scripts\check_ms_windows_disk_load.ps1 "$ARG1$"; exit $LastExitCode | powershell.exe -command -
Can you show us the NSC.ini file? Hide sensitive info.
