"Unable to run check on non-child node. Revise your query."
CatalystX
Post by CatalystX »
We have a single server where we have multiple checks like:
        host_name                       some.host.tld
        service_description             Disk Usage on _boot
        use                             xiwizard_ncpa_service
        check_command                   check_xi_ncpa_agent!-t 'mytoken' -P 5693 -M 'disk/logical/|boot/used_percent' -w 95 -c 98
        max_check_attempts              5
        check_interval                  5
        retry_interval                  1
        check_period                    xi_timeperiod_24x7
        notification_interval           60
        notification_period             xi_timeperiod_24x7
        contact_groups                  Team
        _xiwizard                       ncpa
        register                        1
        service_description             Disk Usage on _opt
        check_command                   check_xi_ncpa_agent!-t 'mytoken' -P 5693 -M 'disk/logical/|opt/used_percent' -w 95 -c 98!!!!!!!
        check_interval                  5
        retry_interval                  1
        contact_groups                  Team
        _xiwizard                       ncpa
        register                        1
The first four checks work perfectly fine (e.g., boot, above). The fifth and sixth checks result in:
We're using NCPA 1.8.1, have restarted it and have uninstalled and reinstalled it to no avail. This configuration works everywhere but "this one" stubborn server, and I can't, for the life of me, figure out why. I've even copied existing configs in CCM to no avail, and if I Test the "working" versions from CCM, they result in the same error.
Any clues?
CatalystX
Re: "Unable to run check on non-child node. Revise your quer
Post by CatalystX »
API call:
returns the expected:
  "value": {
    "used_percent": [
      21.7,
Manual run libexec:
./check_ncpa.py -H some.host.tld -t 'mytoken' -P 5693 -M 'disk/logical/|opt/used_percent' -w 95 -c 98 -sv
Returns:
Connecting to: https://some.host.tld:5693/api/disk/logical/|opt/used_percent/?token=mytoken&warning=95&critical=98&check=1
File returned contained:
  "value": {
    "returncode": 3,
    "stdout": "Unable to run check on non-child node. Revise your query."
Can you go to "https://some.host.tld:5693/api/disk/" and show us everything you have on the page?
Also, run the following command from the CLI (not in the CCM!) and show us the output:
/usr/local/nagios/libexec/check_ncpa.py -H <client ip> -t 'token' -P 5693 -M 'disk/logical/|boot/used_percent' -w 95 -c 98
CatalystX
Post by CatalystX »
|boot works fine. API call to any of them works fine. Command line to anything else:
Connecting to: https://some.host.tld:5693/api/disk/logical/|boot/used_percent/?token=mytoken&warning=95&critical=98&check=1
  "value": {
    "returncode": 0,
    "stdout": "OK: used_percent was 25% | 'used_percent_0'=25%;95;98;"
That's why this is ... crazy.
Let's change this up slightly --- I'm gonna ignore |opt right now as "file system/permissions corruption" and just move on. So ... |svn directory, instead of |opt. Same issues, although -M 'disk/logical/|svn/used_percent' works from the command line, from Test, yet still shows the same error in Service Problems (even after a forced check).
API disk logical:
  "value": {
    "logical": {
      "|boot": {
        "total_size": [
          103512064,
          "b"
        "used_percent": [
          25.6,
        "used": [
          26550272,
          "b"
        "free": [
          71617536,
          "b"
        "device_name": [
            "/dev/sda1"
          "name"
        "total_size": [
          519933952,
          "b"
        "used_percent": [
          88.5,
        "used": [
          460375040,
          "b"
        "free": [
          32715776,
          "b"
        "device_name": [
            "/dev/mapper/VolGroup00-LogVol00"
          "name"
      "|svn": {
        "total_size": [
          21129457664,
          "b"
        "used_percent": [
          21.7,
        "used": [
          4581187584,
          "b"
        "free": [
          15474950144,
          "b"
        "device_name": [
            "/dev/mapper/VolGroup01-LogVol06"
          "name"
CatalystX
Post by CatalystX »
./check_ncpa.py -H some.host.tld -t 'mytoken' -P 5693 -M 'disk/logical/|svn/used_percent' -w 95 -c 98 -sv
Connecting to: https://some.host.tld:5693/api/disk/logical/|svn/used_percent/?token=mytoken&warning=95&critical=98&check=1
  "value": {
    "returncode": 0,
    "stdout": "OK: used_percent was 21% | 'used_percent_0'=21%;95;98;"
"Test Command" works from CCM.
API works (of course, that works on all them anyway).
Check from Nagios?
I note it's send "\|svn" when it checks. Tested with %7c from command line and API, and works fine ... Put into Nagios, same result.
Don't run the command in verbose mode. Just run it as such:
and show us the output.
Go to Home->Service Detail->click on the "problem" service->Configure->Re-configure this service, copy/paste the command that you see there.
Schedule a forced immediate check and show us a screenshot of what you see.
Also, run the following command and show us the output:
/usr/local/nagios/libexec/check_ncpa.py -V
CatalystX
Post by CatalystX »
Umm ... Non-verbose is after the debug code already ... but ok.
From reconfigure.
check_xi_ncpa_agent!-t 'mytoken' -P 5693 -M 'disk/logical/|svn/used_percent' -w 95 -c 98
From Version.
check_ncpa.py, Version 0.3.5
krobertson71
Post by krobertson71 »
Hey this is Kris. I worked with the OP. I will be taking over. Will get you the data shortly.
Thanks.
Kris
@CatalystX can we get confirmation that krobertson71 is working with you?
krobertson71
He is the newest member of our Middleware team and I am the project lead for this for our company. So yes you can.
Also how would I be able to get you the data you need if I didnt???
