i am new to Nagios but now i am a part of Nagios i wanna use Nagios Network Map
i have searched for it a lot but now i have come to know that Nagios work on Linux or Unix But my question from all the users of nagios is to suggest me that what should i do such that i have asp.net application using google map and i am showing my data on that map what should i do so that i can use Nagios in my application where i am using server 2003 OS ?? is it possible
Or what are the alternate methods for doing this ?
Hopes for your suggestions ...
How To Use Nagios With Microsoft Server 2003??
mohsin2011
Re: How To Use Nagios With Microsoft Server 2003??
The only supported distributions are CentOS 5, CentOS 6 and RHEL 5. See this link:
http://support.nagios.com/wiki/index.ph ... tributions
You can use the Windows Server Monitoring Wizard to monitor MS Server 2003. See our documentation on how to use the monitoring wizards:
http://assets.nagios.com/downloads/nagi ... gthewizard
You can view the status of your network by clicking on the "Network Status Map" under "Maps" from the left panel menu in Nagios XI.
You can read this document to find out how to integrate Google map to Nagios XI:
http://assets.nagios.com/downloads/nagi ... ith_XI.pdf
mohsin2011
lmiltchev wrote:The only supported distributions are CentOS 5, CentOS 6 and RHEL 5. See this link:
i have read that how to integrate google map with nagios xi but i wanna ask one more question that in this link it is mention that we can only show the markers only by giving it lat lon value can we create links(Polyline) between those markers in it ??
That feature isn't currently available in our google maps component, but it is an item we'd like to add in the future for parent->child host relationships.
Donald Bracco
I think the best advice was to use the Windows Server Monitoring Wizard to monitor MS Server 2003. The documentation on how to use the monitoring wizards:
Angela_term
Thanks for posting, that was a really detailed guide.Donald Bracco wrote:I think the best advice was to use the Windows Server Monitoring Wizard to monitor MS Server 2003. The documentation on how to use the monitoring wizards:
