Alerting mail link IP
teirekos
Post by teirekos »
When an alert is arriving in our mailboxes it has the following link:
http://127.0.0.1/var/www/html/nagioslog ... UDIud0ai1Q
Can the localhost IP be changed to the "real" IP of the server so the link can actually completely serve it's purpose.
Thanx a lot.
eloyd
Cool Title Here
Re: Alerting mail link IP
Post by eloyd »
You can configure this in the administration section of NLS. Administration | Global Settings, then change the cluster hostname.
jolson
Attack Rabbit
Post by jolson »
eloyd is correct - let us know if you have any trouble with that setting.
Twits Blog
teirekos
Post by teirekos »
Can I put an IP there?
eloyd
Cool Title Here
Post by eloyd »
Yes.
jolson
Attack Rabbit
Post by jolson »
Keep in mind that while putting an IP in that field is possible, it would be wise to use DNS if possible.
Twits Blog
eloyd
Cool Title Here
Post by eloyd »
As an aside, I disagree, but it depends on circumstances.
IP addresses never fail lookups. DNS addresses, by nature, require a DNS server to respond (or caches from a previous lookup). So it is possible that, while an IP address may be harder for human brains to remember or interact with, it is just as useful as a DNS name and immune from DNS injection (or cache poisining) attack, server failure, DNS name resolution issues, and so forth.
And before you say "ya, but a DNS entry is easier to change" - how often do you change the cluster name of a Nagios Log Server entity? :-)
jolson
Attack Rabbit
Post by jolson »
I recommend using a DNS name in this field because all setup instructions will be modified to point to the IP/DNS name in the field. This means that if setup instructions are run as-is, a single node IP will be used (creating a single point of failure). It is true that DNS lookups can fail, but I don't think that excuses the single point of failure in this case, which I see as more dangerous in the long term than a proper DNS entry. All alert emails generated will also point to a single IP.
But of course, as you noted:
Twits Blog
eloyd
Cool Title Here
Post by eloyd »
You are right about cluster names being DNS. For some reason, I was getting my topics confused and thought this was an HA discussion.
Please consider my previous disagreement retracted and yes, the cluster name should be a DNS entry, and if there are multiple servers, then it is easiest to set up as a round-robin list of servers that participate.
jolson
Attack Rabbit
Post by jolson »
teirekos,
Let us know if you have any questions. Thanks!
Twits Blog
