imap input
Envera IT
imap input
Post by Envera IT »
Anyone get the imap input working for logstash? Seems like no matter what I do it crashes with
{:timestamp=>"2015-06-19T12:26:29.290000-0400", :message=>"A plugin had an unrecoverable error. Will restart this plugin.\n  Plugin: <LogStash::Inputs::IMAP type=>\"mail\", host=>\"imap.gmail.com\", user=>\"[email protected]\", content_type=>\"text/plain\">\n  Error: undefined method `encode' for nil:NilClass", :level=>:error}
Here's my input config
imap {
	type => mail
	host => "imap.gmail.com"
	user => "[email protected]"
	password => "mypasswordhere"
	port => 993
	secure => true
	check_interval => 10
I've also tried changing the content option but that hasn't helped. I've confirmed the mails are coming in as Content-Type: text/plain.
After spending around two hours trying to get it setup I've run out of google results. Need to be able to accept emails as an input in logstash as we have a few hundred devices that only support email for alert generation.
I like graphs...
jolson
Attack Rabbit
Re: imap input
Post by jolson »
Typically this error is a result of improper syntax on the input. Could you try the following?
imap {
   type => mail
   port => 993
   user => [email protected]
   password => mypasswordhere
   secure => "true"
Twits Blog
Envera IT
Re: imap input
Post by Envera IT »
jolson wrote:Typically this error is a result of improper syntax on the input. Could you try the following?
imap {
   type => mail
   port => 993
   secure => "true"
THANK YOU :D :D :D good to go on my end now.
I like graphs...
jolson
Attack Rabbit
Re: imap input
Post by jolson »
No problem. I'll lock this thread up. Let us know if you have any further questions!
Jesse
Reason: Unlocked topic per request.
Twits Blog
Envera IT
Re: imap input
Post by Envera IT »
Still having issues with the imap plugin. I've traced it to an issue with the content_type variable. Basically I'm not sure how to work with multipart messages. Want to add that I'm testing this on a fresh NLS install with nothing else running on it. Symptom is the same, after successfully pulling emails in from the mail box for awhile, the plugin crashes and logstash with it. Logstash needs to be manually restarted after this happens.
My input looks like this.
imap {
type => mail
port => 993
secure => "true"
Logstash documentation just says - https://www.elastic.co/guide/en/logstas ... ntent_type
content_type
Value type is string
Default value is "text/plain"
For multipart messages, use the first part that has this content-type as the event message.
These are the logstash.log errors I'm getting.
{:timestamp=>"2015-06-19T11:50:16.689000-0400", :message=>"A plugin had an unrecoverable error. Will restart this plugin.\n Plugin: <LogStash::Inputs::IMAP type=>\"mail\", host=>\"imap.gmail.com\", user=>\"[email protected]\", content_type=>\"text/plain\">\n Error: Can not decode an entire message, try calling #decoded on the various fields and body or parts if it is a multipart message.", :level=>:error}
The raw email I'm receiving from the device is this,
Return-Path: <[email protected]>
Received: from localhost (redacted. [redacted])
by mx.google.com with ESMTPSA id z194sm7851754ywz.56.2015.06.24.05.39.17
for <[email protected]>
(version=TLSv1.2 cipher=ECDHE-RSA-AES128-SHA bits=128/128);
Wed, 24 Jun 2015 05:39:18 -0700 (PDT)
Message-ID: <372554.386357905-sendEmail@localhost>
To: "[email protected]" <[email protected]>
Subject: 0001 redactedTEST: 24-06-15 08:39:38 - Z000 1055 REAL 001 SYSTEM |CAM01 LIVE VIEW
Date: Wed, 24 Jun 2015 12:39:39 +0000
X-Mailer: sendEmail-1.56
MIME-Version: 1.0
Content-Type: multipart/related; boundary="----MIME delimiter for sendEmail-167244.87494594"
This is a multi-part message in MIME format. To properly display this message you need a MIME-Version 1.0 compliant Email program.
------MIME delimiter for sendEmail-167244.87494594
Content-Type: text/plain;
charset="iso-8859-1"
------MIME delimiter for sendEmail-167244.87494594--
I really just need this part of the message,
Seems to be related to this - https://logstash.jira.com/browse/LOGSTASH-2080 which given the lack of updates is disheartening :cry:
Any advice?
I like graphs...
jolson
Attack Rabbit
Re: imap input
Post by jolson »
Please give the following a try:
imap {
type => mail
port => 993
secure => "true"
content_type => "text/html"
I agree that this looks like a possibly longstanding bug in logstash - I am hoping that the above will work for you.
Twits Blog
Envera IT
Re: imap input
Post by Envera IT »
I've made the change, will report back on what I find in a day or two. Thanks for the help so far!
I like graphs...
Re: imap input
Sure thing. Keep us posted!
jolson
Attack Rabbit
Re: imap input
Post by jolson »
No problem! Let us know what you find out.
Twits Blog
eloyd
Cool Title Here
Re: imap input
Post by eloyd »
Sure thing. No problem! Keep us posted one what you find out.
:mrgreen:
