SNMP is not working for few services
I am trying to put a solaris machine under monitoring.
OS version - SunOS 5.10 Generic_144489-06 i86pc i386 i86pc
SNMP is working fine on the server and it is collecting data for few services , but few other services it is not working.
For example it is collecting data for swap memory usage but physical memory usage is giving error
Unknown storage : Physical memory : ERROR
Could you please help me to resolve this issue.
Regards
Regards
Re: SNMP is not working for few services
Are you using Sun's SNMP implementation or did you install net-snmp?
Hi ssax,
I am using Sun's SNMP implementation.
Can you run a snmpwalk or your Solaris server and post the output back here?
Could you also post how you are running the check command that is failing for you?
snmpwalk <IP Address> -v 2c -c <Community String>Be sure to check out our Knowledgebase for helpful articles and solutions!
if you are using check_snmp plugin you can use verbose (-v) and see at what OID it is trying and as suggested by tgriep try snmpwalk and match the OID.
You can grep the output of the snmpwalk to limit (filter) the results. An example:
snmpwalk x.x.x.x -v 2c -c <community> | grep -i memory
HOST-RESOURCES-MIB::hrMemorySize.0 = INTEGER: 4019552 KBytes
HOST-RESOURCES-MIB::hrStorageType.3 = OID: HOST-RESOURCES-TYPES::hrStorageVirtualMemory
HOST-RESOURCES-MIB::hrStorageType.10 = OID: HOST-RESOURCES-TYPES::hrStorageVirtualMemory
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memoryBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi
Please find the output below.
COMMAND: /usr/local/nagios/libexec/check_snmp_storage.pl -H HOSTNAME -C STRING -m 'Physical memory' -w 99 -c 100 -f -o 5000
~]# snmpwalk HOSTNAME -v 2c -c STRING| grep -i memory
HOST-RESOURCES-MIB::hrMemorySize.0 = INTEGER: 150985828 KBytes
HOST-RESOURCES-MIB::hrStorageDescr.2 = STRING: Real Memory
Timeout: No Response from HOSTNAME
Command output in verbose mode.
/usr/local/nagios/libexec/check_snmp_storage.pl -H HOSTNAME -C STRING -m 'Physical memory' -w 99 -c 100 -f -o 5000 -v
Alarm at 15
SNMP v1 login
actual max octets:: 1472
new max octets:: 5000
Filter : Physical memory
OID : 1.3.6.1.2.1.25.2.3.1.3.14, Desc : /tmp
OID : 1.3.6.1.2.1.25.2.3.1.3.19, Desc : /u01/appl
OID : 1.3.6.1.2.1.25.2.3.1.3.8, Desc : /etc/mnttab
OID : 1.3.6.1.2.1.25.2.3.1.3.16, Desc : /LOCAL
OID : 1.3.6.1.2.1.25.2.3.1.3.9, Desc : /etc/svc/volatile
OID : 1.3.6.1.2.1.25.2.3.1.3.6, Desc : /system/contract
OID : 1.3.6.1.2.1.25.2.3.1.3.20, Desc : /edsbackup
OID : 1.3.6.1.2.1.25.2.3.1.3.15, Desc : /var/run
OID : 1.3.6.1.2.1.25.2.3.1.3.18, Desc : /patch
OID : 1.3.6.1.2.1.25.2.3.1.3.17, Desc : /home
OID : 1.3.6.1.2.1.25.2.3.1.3.4, Desc : /
OID : 1.3.6.1.2.1.25.2.3.1.3.11, Desc : /etc/dfs/sharetab
OID : 1.3.6.1.2.1.25.2.3.1.3.12, Desc : /lib/libc.so.1
OID : 1.3.6.1.2.1.25.2.3.1.3.7, Desc : /proc
OID : 1.3.6.1.2.1.25.2.3.1.3.3, Desc : Swap Space
OID : 1.3.6.1.2.1.25.2.3.1.3.10, Desc : /system/object
OID : 1.3.6.1.2.1.25.2.3.1.3.2, Desc : Real Memory
OID : 1.3.6.1.2.1.25.2.3.1.3.5, Desc : /devices
OID : 1.3.6.1.2.1.25.2.3.1.3.13, Desc : /var
storages selected : 0
Alarm at 15
SNMP v1 login
If you are trying to check the amount of memory or storage space?
If you are trying to check the memory of the server you should use the check_snmp_mem.pl plugin.
Hi
I tried with check_snmp_mem.pl plugin, but It is complaining about the format I used for the command. I am not sure what login credentials it is looking for other than community string.
We are getting unknown error for CPU load as well.
Regards
Tino
COMMAND: /usr/local/nagios/libexec/check_snmp_mem.pl -H HOSTNAME -C STRING -w 99 -c 100 -f
OUTPUT: 2 warnings and critical !
Usage: /usr/local/nagios/libexec/check_snmp_mem.pl [-v] -H -C [-2] | (-l login -x passwd [-X pass -L ,]) [-p ] Code: Select all
COMMAND: /usr/local/nagios/libexec/check_snmp_load.pl -H HOSTNAME -C STRING -w 99 -c 100 -T stand -f
OUTPUT: Can't find CPU usage information : UNKNOWNTino
