# Timeperiod configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date: 2015-06-26 13:33:28
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define timeperiod {
alias Notification Times for cimb ib gcls app support
timeperiod_name cimb ib gcls app support_notification_times
monday 00:00-24:00
tuesday 00:00-24:00
wednesday 00:00-24:00
thursday 00:00-24:00
friday 00:00-24:00
saturday 00:00-24:00
sunday 00:00-24:00
The timeperiod above is causing Apply configuration to fail. If I delete this from the timeperiod.cfg config files and restart the nagios service it starts up fine.
Please advice how to get rid of this entry. It cannot be found in the CCM - TimePeriod.
You didn't define this time period in the "/usr/local/nagios/etc/static/" directory, did you? Do you get any config errors, when you run the Write Config Tool?
After you delete this entry from the timeperiod.cfg, does it still cause an error when you Apply the Configuration?
If so, can you run the following in a shell, Apply the Configuration and post back the output of the tail command?
lmiltchev wrote:You didn't define this time period in the "/usr/local/nagios/etc/static/" directory, did you? Do you get any config errors, when you run the Write Config Tool?
Can you go to the CCM->Time Periods, enter "cimb" in the "Search" bar, hit "Enter", and show us a screenshot of the results?
No nothing was added in etc/static.
Tried the Write, Delete, Write, Verify.
It took me 3 Write cycles before it finally writes all to the disk. First few times it just stops half way.
Verify complains this and that was missing.
After that it started up just fine.
tgriep wrote:After you delete this entry from the timeperiod.cfg, does it still cause an error when you Apply the Configuration?
