Save perfdata on other database
cristhofer.perez
Post by cristhofer.perez »
I'm trying to save the perfdata of some services on my own DB. I only need to know what scripts have the information that I need. What scripts do this task? I mean, What script written in the rrd files? Can it be modified for this purposes?
I would like to take all the perfdata taken from nagios and send them to my own script, that take the values and save with my own format.
Can any of you help me?
BR,
Cristhofer
Re: Save perfdata on other database
What type of services are we talking about? Also, may I ask why you need to use your "own format"? What are you trying to accomplish? Such a customization wouldn't be supported and we would not recommend implementing it.
cristhofer.perez
Thanks, I have a good solution. I decided tu use: Obsessive Compulsive Service Processor Command
That is an often-overlooked aspect of Core, glad it worked for you!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
