I'm trying to run the NagiosXI-Nagvis.sh
-rwx------ 1 root root 5331 Jun 29 2011 NagiosXI-Nagvis.sh
the installation appears to fail with the following error
Installed:
graphviz.x86_64 0:2.26.0-10.el6
Complete!
./NagiosXI-Nagvis.sh: line 128: ./install.sh: Permission denied
NagVis installation
Re: NagVis installation
What version of XI are you running? NagVis has shipped with XI for a number of major versions. It should be reachable through Home --> NagVis.
Why are you running the “NagiosXI-Nagvis.sh” script? Are you trying to integrate NagVis in Nagios XI, older than 2012?
If you are using XI 2012 or newer, NagVis is installed by default...
https://assets.nagios.com/downloads/nag ... ith_XI.pdfImportant:
This document is outdated as all versions of Nagios XI (2012 and newer) ship with
NagiVis by default and the “NagiosXI-Nagvis.sh” install script should NOT be run!
thank you for the input, after I posted the light bulb came on and I remember that we restrict what can run under tmp. so I had to mod the script so it cd to ~/ and the install finished fine.
No problem. Can we close this thread?
