Nagios not working after Update
Darth_Panda
Hi Guys,
I posted this is the Debian forums but I thoought I might post it here too just in case someone knows a quick fix. I am running Debian Wheezy with Nagios Core and Cacti. I ran this command to try and fix an issue with Exim - #apt-get install swaks libnet-ssleay-perl. The system proceeded to completely updated itself which took quite a few minutes. Now Nagios does not answer on the URL and I am also seeing this message below. Should I start with a new box or is there a way to save Nagios?
root@watchtower:~# dpkg-reconfigure apache2
insserv: Script nagios is broken: incomplete LSB comment.
insserv: missing `Default-Start:' entry: please add even if empty.
insserv: missing `Default-Stop:' entry: please add even if empty.
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `nagios'
insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `nagios'
Restarting web server: apache2AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.16.1.231. Set the 'ServerName' directive globally to suppress this message
- Box293
- Too Basu
Re: Nagios not working after Update
It may just be apache that is broken, nagios itself may still be running ok.
If nagios is running then thats a good thing.
/etc/init.d/nagios statusAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Darth_Panda
It still seems to be running. There are over 1000 host files that still seem to be in tact also.Box293 wrote:It may just be apache that is broken, nagios itself may still be running ok.
root@watchtower:~# /etc/init.d/nagios status
nagios (pid 2979) is running...
- Box293
- Too Basu
Great.
What are the apache logs saying:
tail -n 25 /var/log/apache2/error.log
tail -n 25 /var/log/apache2/access.logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Darth_Panda
root@watchtower:~# tail -n 25 /var/log/apache2/error.logBox293 wrote:Great.
tail -n 25 /var/log/apache2/error.log tail -n 25 /var/log/apache2/access.log
[Tue Jun 30 06:25:09.260472 2015] [mpm_prefork:notice] [pid 32179] AH00163: Apache/2.4.10 (Debian) PHP/5.6.9-0+deb8u1 configured -- resuming normal operations
[Tue Jun 30 06:25:09.260531 2015] [core:notice] [pid 32179] AH00094: Command line: '/usr/sbin/apache2'
[Tue Jun 30 08:45:52.038822 2015] [mpm_prefork:notice] [pid 32179] AH00169: caught SIGTERM, shutting down
[Tue Jun 30 08:45:53.094936 2015] [mpm_prefork:notice] [pid 14693] AH00163: Apache/2.4.10 (Debian) PHP/5.6.9-0+deb8u1 configured -- resuming normal operations
[Tue Jun 30 08:45:53.095028 2015] [core:notice] [pid 14693] AH00094: Command line: '/usr/sbin/apache2'
root@watchtower:~# tail -n 25 /var/log/apache2/access.log
root@watchtower:~#
- Box293
- Too Basu
Run this command:Darth_Panda wrote: Now Nagios does not answer on the URL
tail -f /var/log/apache2/error.logI did create a guide for installing Nagios Core from Source on Debian a while ago, have a look through this and see if any of this helps:
http://sites.box293.com/nagios/guides/i ... bian-7-7-0
Darth_Panda
This is what I get;Box293 wrote:
So what message are you getting in your browser when you access the URL? Also anything logged in the ssh session when you access the URL.
Not Found
The requested URL /nagios/ was not found on this server.
Apache/2.4.10 (Debian) Server at 172.16.1.98 Port 80
Thanks for the guide.
Darth_Panda
Is there any way I could follow your instructions but re-install Nagios without starting from scratch. I have cacti which is still working so my preference would be to not wipe the hard drive.If I remove MySQL I think that will effect Cacti also.Box293 wrote:
- Box293
- Too Basu
Honestly I just think the problem lies in apache so the main things I would look at are:
User And Group:
File permissions:
check appache users:
is iptables installed / filewall rule allows inbound?
Some apache stuff:
Apart from that not a lot is standing out.
User And Group:
grep nagios /etc/passwd
grep www-data /etc/passwd
grep nagios /etc/groupCode: Select all
chown -R nagios:nagios /usr/local/nagiosCode: Select all
htpasswd -c -b /usr/local/nagios/etc/htpasswd.users nagiosadmin nagiosadminpasswordCode: Select all
iptables status
iptables -I INPUT -p tcp --destination-port 80 -j ACCEPT
apt-get install -y iptables-persistentCode: Select all
a2enmod rewrite
a2enmod cgi
/etc/init.d/apache2 restartApart from that not a lot is standing out.
Honesly I haven't used Cactl and the Debian guide I created was a learning exercise for myself.Darth_Panda wrote:Is there any way I could follow your instructions but re-install Nagios without starting from scratch. I have cacti which is still working so my preference would be to not wipe the hard drive.If I remove MySQL I think that will effect Cacti also.
Darth_Panda
[quote="Box293"]Honestly I just think the problem lies in apache so the main things I would look at are:
User And Group:
File permissions:
Some apache stuff:
User And Group:
iptables status
a2enmod rewrite
a2enmod cgi
root@watchtower:~# grep nagios /etc/passwd
nagios:x:1000:1000:,,,:/home/nagios:/bin/bash
root@watchtower:~# grep www-data /etc/passwd
www-data:x:33:33:www-data:/var/www:/bin/sh
root@watchtower:~# grep nagios /etc/group
nagios:x:1000:www-data
root@watchtower:~# chown -R nagios:nagios /usr/local/nagios
root@watchtower:~# htpasswd -c -b /usr/local/nagios/etc/htpasswd.users nagiosadmin nagiosadminpassword
Adding password for user nagiosadmin
root@watchtower:~# iptables status
Bad argument `status'
Try `iptables -h' or 'iptables --help' for more information.
root@watchtower:~# iptables -I INPUT -p tcp --destination-port 80 -j ACCEPT
root@watchtower:~# apt-get install -y iptables-persistent
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
init-system-helpers netfilter-persistent
The following NEW packages will be installed:
init-system-helpers iptables-persistent netfilter-persistent
0 upgraded, 3 newly installed, 0 to remove and 427 not upgraded.
2 not fully installed or removed.
Need to get 32.9 kB of archives.
After this operation, 247 kB of additional disk space will be used.
Get:1 http://mirror.optus.net/debian/ stable/main init-system-helpers all 1.22 [14.0 kB]
Get:2 http://mirror.optus.net/debian/ stable/main netfilter-persistent all 1.0.3 [8,036 B]
Get:3 http://mirror.optus.net/debian/ stable/main iptables-persistent all 1.0.3 [10.8 kB]
Fetched 32.9 kB in 0s (114 kB/s)
Preconfiguring packages ...
Package configuration
┌────────────────────────────────────────────────────────────┠│ptables-persistent ├──────────────────────────────────────────────â│”€â”€â”€â”€â”€â”€â
│ Current iptables rules can be saved to the configuration file /etc/iptables/rules.v4. These rules will then be loaded automatically during system startup. │
│ Rules are only saved automatically during package installation. See the manual page of iptables-save(8) for instructions on keeping the rules file up-to-date. │
│ Save current IPv4 rules? │
│ <Yes> <No> │
┌────────────────────────────────────────────────────────────┠│ptables-persistent ├──────────────────────────────────────────────â”│€â”€â”€â”€â”€â”€â
│ Current iptables rules can be saved to the configuration file /etc/iptables/rules.v6. These rules will then be loaded automatically during system startup. │
│ Rules are only saved automatically during package installation. See the manual page of ip6tables-save(8) for instructions on keeping the rules file up-to-date. │
│ Save current IPv6 rules? │
│ <Yes> <No> │
Selecting previously unselected package init-system-helpers.
(Reading database ... 49562 files and directories currently installed.)
Preparing to unpack .../init-system-helpers_1.22_all.deb ...
Unpacking init-system-helpers (1.22) ...
Selecting previously unselected package netfilter-persistent.
Preparing to unpack .../netfilter-persistent_1.0.3_all.deb ...
Unpacking netfilter-persistent (1.0.3) ...
Selecting previously unselected package iptables-persistent.
Preparing to unpack .../iptables-persistent_1.0.3_all.deb ...
update-rc.d: using dependency based boot sequencing
Unpacking iptables-persistent (1.0.3) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up nagios3-common (3.5.1.dfsg-2) ...
Starting nagios3 monitoring daemon: nagios3
Nagios Core 3.5.1
Last Modified: 08-30-2013
License: GPL
Reading configuration data...
Error: Cannot open resource file '/etc/nagios3/resource.cfg' for reading!
Read main config file okay...
Processing object config file '/etc/nagios3/commands.cfg'...
Error: Cannot open config file '/etc/nagios3/commands.cfg' for reading: No such file or directory
errors in config! ... failed!
failed!
invoke-rc.d: initscript nagios3, action "start" failed.
dpkg: error processing package nagios3-common (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of nagios3-core:
nagios3-core depends on nagios3-common (= 3.5.1.dfsg-2); however:
Package nagios3-common is not configured yet.
dpkg: error processing package nagios3-core (--configure):
dependency problems - leaving unconfigured
Setting up init-system-helpers (1.22) ...
Setting up netfilter-persistent (1.0.3) ...
Loading netfilter rules...run-parts: executing /usr/share/netfilter-persistent/plugins.d/15-ip4tables start
Warning: skipping IPv4 (no rules to load)
run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
Warning: skipping IPv6 (no rules to load)
done.
Setting up iptables-persistent (1.0.3) ...
Errors were encountered while processing:
nagios3-common
nagios3-core
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@watchtower:~# a2enmod rewrite
Enabling module rewrite.
To activate the new configuration, you need to run:
service apache2 restart
root@watchtower:~# a2enmod cgi
Module cgi already enabled
root@watchtower:~# /etc/init.d/apache2 restart
