Hi ,
i have installed nagiosxi-4-2.7.el6.x86_64.tar.gz version offline. i am not geeting loging GUI page.
[root@nms-hp1-12-sm nagiosxi]# ./fullinstall
Loaded plugins: security
Setting up Local Package Process
Examining libmcrypt-2.5.8-9.el6.x86_64.rpm: libmcrypt-2.5.8-9.el6.x86_64
libmcrypt-2.5.8-9.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-4-2.7.el6.x86_64.rpm: nagiosxi-4-2.7.el6.x86_64
nagiosxi-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-ajaxterm-4-2.7.el6.x86_64.rpm: nagiosxi-ajaxterm-4-2.7.el6.x86_64
nagiosxi-ajaxterm-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-mrtg-4-2.7.el6.x86_64.rpm: nagiosxi-mrtg-4-2.7.el6.x86_64
nagiosxi-mrtg-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagioscore-4-2.7.el6.x86_64.rpm: nagiosxi-nagioscore-4-2.7.el6.x86_64
nagiosxi-nagioscore-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagiosmobile-4-2.7.el6.x86_64.rpm: nagiosxi-nagiosmobile-4-2.7.el6.x86_64
nagiosxi-nagiosmobile-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagiosplugins-4-2.7.el6.x86_64.rpm: nagiosxi-nagiosplugins-4-2.7.el6.x86_64
nagiosxi-nagiosplugins-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagiosql-4-2.7.el6.x86_64.rpm: nagiosxi-nagiosql-4-2.7.el6.x86_64
nagiosxi-nagiosql-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagvis-4-2.7.el6.x86_64.rpm: nagiosxi-nagvis-4-2.7.el6.x86_64
nagiosxi-nagvis-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-ndoutils-4-2.7.el6.x86_64.rpm: nagiosxi-ndoutils-4-2.7.el6.x86_64
nagiosxi-ndoutils-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nrds-4-2.7.el6.x86_64.rpm: nagiosxi-nrds-4-2.7.el6.x86_64
nagiosxi-nrds-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nrpe-4-2.7.el6.x86_64.rpm: nagiosxi-nrpe-4-2.7.el6.x86_64
nagiosxi-nrpe-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nsca-4-2.7.el6.x86_64.rpm: nagiosxi-nsca-4-2.7.el6.x86_64
nagiosxi-nsca-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-pnp-4-2.7.el6.x86_64.rpm: nagiosxi-pnp-4-2.7.el6.x86_64
nagiosxi-pnp-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-wkhtmltox-4-2.7.el6.x86_64.rpm: nagiosxi-wkhtmltox-4-2.7.el6.x86_64
nagiosxi-wkhtmltox-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-wmic-4-2.7.el6.x86_64.rpm: nagiosxi-wmic-4-2.7.el6.x86_64
nagiosxi-wmic-4-2.7.el6.x86_64.rpm: does not update installed package.
Examining perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm: perl-Crypt-Rijndael-1.09-2.el6.x86_64
perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm: does not update installed package.
Examining perl-Mail-IMAPClient-3.34-1.el6.noarch.rpm: perl-Mail-IMAPClient-3.34-1.el6.noarch
perl-Mail-IMAPClient-3.34-1.el6.noarch.rpm: does not update installed package.
Examining perl-Mail-POP3Client-2.18-6.el6.noarch.rpm: perl-Mail-POP3Client-2.18-6.el6.noarch
perl-Mail-POP3Client-2.18-6.el6.noarch.rpm: does not update installed package.
Examining perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm: perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch
perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm: does not update installed package.
Examining perl-Net-SNMP-5.2.0-4.el6.noarch.rpm: perl-Net-SNMP-5.2.0-4.el6.noarch
perl-Net-SNMP-5.2.0-4.el6.noarch.rpm: does not update installed package.
Examining php-mcrypt-5.3.3-3.el6.x86_64.rpm: php-mcrypt-5.3.3-3.el6.x86_64
php-mcrypt-5.3.3-3.el6.x86_64.rpm: does not update installed package.
Examining php-mssql-5.3.3-3.el6.x86_64.rpm: php-mssql-5.3.3-3.el6.x86_64
php-mssql-5.3.3-3.el6.x86_64.rpm: does not update installed package.
Examining php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: does not update installed package.
Examining php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm: php-pecl-ssh2-0.11.0-7.el6.x86_64
php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm: does not update installed package.
Examining pymssql-1.0.2-4.el6.x86_64.rpm: pymssql-1.0.2-4.el6.x86_64
pymssql-1.0.2-4.el6.x86_64.rpm: does not update installed package.
Examining python-bson-2.5.2-3.el6.x86_64.rpm: python-bson-2.5.2-3.el6.x86_64
python-bson-2.5.2-3.el6.x86_64.rpm: does not update installed package.
Examining python-pymongo-2.5.2-3.el6.x86_64.rpm: python-pymongo-2.5.2-3.el6.x86_64
python-pymongo-2.5.2-3.el6.x86_64.rpm: does not update installed package.
Nothing to do
Sudhakar Anguri
Nagiosxi offline installation
jdalrymple
- Skynet Drone
Re: Nagiosxi offline installation
When you run the offline installer there is an installation log created in the /tmp directory. I don't recall the name of it off-hand, but it's obvious when you see it, something like 'nagios.log'
Take a look at that. If you'd like us to review it, post it here inside code wraps.
angurisudhakar
i could not find any log file name nagio.log or any log file extension in /tmp folder .
[root@nms-hp1-12-sm nagiosxi]# ls -ltr
total 114956
-rwxr-xr-x 1 root root 53 Apr 23 21:02 upgrade
-rw-r--r-- 1 root root 226601 Apr 23 21:02 nagiosxi-ndoutils-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 2037550 Apr 23 21:02 nagiosxi-nagvis-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 916069 Apr 23 21:02 nagiosxi-nagiosql-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 3206535 Apr 23 21:02 nagiosxi-nagiosplugins-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 123233 Apr 23 21:02 nagiosxi-nagiosmobile-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 5199925 Apr 23 21:02 nagiosxi-nagioscore-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 274143 Apr 23 21:02 nagiosxi-mrtg-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 85382 Apr 23 21:02 nagiosxi-ajaxterm-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 44039652 Apr 23 21:02 nagiosxi-4-2.7.el6.x86_64.rpm
-rwxr-xr-x 1 root root 53 Apr 23 21:02 fullinstall
-rw-r--r-- 1 root root 32669 Apr 23 21:02 nagiosxi-pnp-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 44767 Apr 23 21:02 nagiosxi-nsca-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 67548 Apr 23 21:02 nagiosxi-nrpe-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 23000063 Apr 23 21:02 nagiosxi-nrds-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 6803745 Apr 23 21:02 nagiosxi-wmic-4-2.7.el6.x86_64.rpm
-rw-r--r-- 1 root root 30261271 Apr 23 21:02 nagiosxi-wkhtmltox-4-2.7.el6.x86_64.rpm
-rwxr--r-x 1 root root 31471 Apr 23 21:02 php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm
-rwxr--r-x 1 root root 101488 Apr 23 21:02 perl-Net-SNMP-5.2.0-4.el6.noarch.rpm
-rwxr--r-x 1 root root 13464 Apr 23 21:02 perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm
-rwxr--r-x 1 root root 25960 Apr 23 21:02 perl-Mail-POP3Client-2.18-6.el6.noarch.rpm
-rwxr--r-x 1 root root 229892 Apr 23 21:02 perl-Mail-IMAPClient-3.34-1.el6.noarch.rpm
-rwxr--r-x 1 root root 97428 Apr 23 21:02 libmcrypt-2.5.8-9.el6.x86_64.rpm
-rwxr--r-x 1 root root 218988 Apr 23 21:02 python-pymongo-2.5.2-3.el6.x86_64.rpm
-rwxr--r-x 1 root root 111648 Apr 23 21:02 python-bson-2.5.2-3.el6.x86_64.rpm
-rwxr--r-x 1 root root 44468 Apr 23 21:02 pymssql-1.0.2-4.el6.x86_64.rpm
-rwxr--r-x 1 root root 30736 Apr 23 21:02 php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm
-rwxr--r-x 1 root root 27468 Apr 23 21:02 php-mssql-5.3.3-3.el6.x86_64.rpm
-rwxr--r-x 1 root root 18484 Apr 23 21:02 php-mcrypt-5.3.3-3.el6.x86_64.rpm
-rwxr--r-x 1 root root 31272 Apr 23 21:02 perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm
[root@nms-hp1-12-sm nagiosxi]# pwd
/tmp/nagiosxi
Sudhakar Anguri.
total 114956
/tmp/nagiosxi
Sudhakar Anguri.
jdalrymple
- Skynet Drone
Sorry - I had to go through the fullinstall process to find it myself.
The file is /tmp/xi-install.log
Do you have that file?
[jdalrymple@localhost tmp]$ ls
xi-install.log yum.log
angurisudhakar
which you mentions log file names are not find in my /tmp/ folder.
Please help me out.
Please help me out.
jdalrymple
- Skynet Drone
The problem right now is that we have nothing to go on. The output you displayed above is not from the original run of fullinstall, it's from a subsequent run.
My suspicion is that your rpm did indeed fail to install properly. What is the contents of the directory /usr/local/nagiosxi? I suspect it's empty or non-existent.
All that said, it's really hard to troubleshoot without that log. The fact that the log is missing is definitely suspect. I have no idea why that log wouldn't be created on your system, it works fine on mine. What type of system are we talking about? RHEL? CentOS? Did you do a minimal install or did you add in any other packages or repos? Did you load from a custom repo? Do you have any other weird system customizations. Did you be sure to run everything as root?
Without anything to go on but a rehash of the fullinstall the only suggestion we can offer is to start from scratch. It may be easier to do that anyway.
angurisudhakar
Thanks for your input ,sure i will check and let know
jdalrymple
- Skynet Drone
This should be fairly quick and easy and would be a great place to start...jdalrymple wrote:My suspicion is that your rpm did indeed fail to install properly. What is the contents of the directory /usr/local/nagiosxi? I suspect it's empty or non-existent.
