Hello all, I'm new in Nagios.
I just deploy Nagios and start a wizard to add a windows server. Its runs fine, but, if I want to add other process to monitor, for example, I'm monitoring explorer.exe, and now want to monitor skype.exe, how can I edit a host detail?
Thanks in advance!
Edit host detail
jdalrymple
- Skynet Drone
Re: Edit host detail
Simply go through the wizard again. This will add services to the host if you use the same address and hostname. It will not remove already created services.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
