check_by_ssh time out issue
I am trying to monitor few servers using SSH, but I am getting the error below. if I run the check from the CLI works fine. I am running the check as root and also as Nagios.
Critical
Command: /usr/bin/ssh
Argument 1: myIPADDRESS
Argument 2: /usr/local/nagios/libexec/check_disk /
CRITICAL - Plugin timed out after 10 seconds
Critical
Re: check_by_ssh time out issue
Could you post how you have the check setup in Nagios XI and how you ran it from the command line?
For your second arguments, do you have them in double quotes? That may be needed because of the space in the command.
I do have them with double quotes
# ./check_by_ssh -H myserver -C "/usr/local/nagios/libexec/check_disk /"
DISK OK - free space: / 324 MB (56% inode=90%);| /=251MB;;;0;576
I tested your example and it worked for me. Lets check and see if you can ssh in to the remote system without being prompted for a password. Try running this on the XI system in a shell.
Post back the output.
Is should not prompt for a password.
su nagios
ssh <IP Address of the remote system>Is should not prompt for a password.
[nagios@nagmonus1 ~]$ ssh myserver
Last unsuccessful login: Thu Jul 2 07:04:10 EDT 2015 on ssh from nagmonus1.bose.com
Last login: Thu Jul 2 08:27:40 EDT 2015 on /dev/pts/1 from nagmonus1.bose.com
* Welcome to AIX Version 7.1! *
* Please see the README file in /usr/lpp/bos for information pertinent to *
* this release of the AIX Operating System. *
[YOU HAVE NEW MAIL]
[YOU HAVE NEW MAIL]
Can you also try timing the check, even though it is highly unlikely it actually timed out...
su nagios
time /usr/local/nagios/libexec/check_by_ssh -H x.x.x.x -C "/usr/local/nagios/libexec/check_disk /" -v
Argument 1: x.x.x.x
DISK OK - free space: / 4850 MB (29% inode=70%);| /=11801MB;;;0;17544
real 0m0.129s
user 0m0.008s
sys 0m0.002sBe sure to check out our Knowledgebase for helpful articles and solutions!
from CLI, here is the result
[nagios@nagmonus1 ~]$ time /usr/local/nagios/libexec/check_by_ssh -H myserver -C "/usr/local/nagios/libexec/check_disk /" -v
Argument 1: myserver
real 0m0.620s
user 0m0.015s
sys 0m0.011s
You have mail in /var/spool/mail/nagios
real 0m0.620s
user 0m0.015s
sys 0m0.011s
Can you find any clues in the remote server's logs? I am not sure where the AIX version of "secure" log would be... "/var/log/authlog"? Also, check the nagios.log on the Nagios XI server.
tail -100 /usr/local/nagios/var/nagios.logBe sure to check out our Knowledgebase for helpful articles and solutions!
[1435836260] SERVICE ALERT: ac1db1.bose.com;Check root;UNKNOWN;SOFT;1;Remote command execution failed: ssh: connect to host 10.0.x.x port 22: Connection timed out
Reason: omitted some IP information
Anything in the remote logs?
