Database connection error
eddiez
Post by eddiez »
I am getting the following when trying to access my Nagios system.
Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
I ran the script listed and still get this message. At this point my production system is down.
Re: Database connection error
Sometimes one needs to run the database repair script a few times before ALL of the errors are fixed. Did you check the mysql log for errors (crashed tables) after you ran the script?
tail /var/log/mysqld.log
Do you still see some errors?
Also, it is possible that the problem is not related to mysql database but postgres. Can you restart postgres and check if it is running?
service postgresql restart
service postgresql status
Did you run out of disk space? What is the output of the following commands?
df -h
df -i
eddiez
Post by eddiez »
Issue resolved, thanks.
