Hi All,
I can no longer scroll though all the pages in the state history / any of the multi page reports within the buttons at the bottom of the screen(See attachment). I can however download the report as pdf or csv and view everything. I am using FFOX.
XI 1.7..
Cheers
Arnab
Cannot scroll pages reports in XI 1.7
Re: Cannot scroll pages reports in XI 1.7
This is a known bug in newer versions of Firefox but we are still trying to track down the cause.
arnab.roy,
Just curious... If you right-click on the page and go to: "This frame"->"Open Frame in New Window", can you then scroll through the pages?
You are spot on mate, If I open the frame up in a diff tab or window it works, am not surprised considering the amount of release FFOX have been making
Just to let you know anything above ffox 4.0 i.e. 5 and 6 its broken...
Thanks for the input, if you come across any other clues or specific page elements where this keeps happening let us know, this one could be a bit sneaky ; )
The one that I have posted i.e. status history is consistent with the non-responsiveness. However I have also seen wierd behaviour within the user management section(could select all users apart from one !).
I think I found the cause of this. A second (empty) footer is being generated in the main content page of XI. Since it uses absolute positioning it's being overlayed on top of the page content and prevent buttons and links from working. I'll try and get a patch ready tomorrow since this bug can prevent some pages from working if they're not opened in a new tab.
yes that's true I realised that today while giving a demo on Chrome
Fixed this in SVN for the 1.8 release. Let us know if you want a patch before then
