1.) We have literally hundreds of dashboards created by users that we would like to migrate to the 'global' account though we only see the option to manually upload dashboards - one at a time - via their individual .json files. Is there no repository where these json files can be bulk uploaded?
2.) Is there a limit to how many dashboards we can have in one account - particularly those made global?
Bulk uploading dashboards
Re: Bulk uploading dashboards
There is no built-in way to do this using the Web GUI. I tried a couple of command-line methods out, but to my knowledge this procedure must be done using the GUI.
The following procedure at git: https://github.com/elastic/kibana/issues/333 did not work for me. I have submitted an internal feature request for this functionality.
To my knowledge there is not a limit to how many dashboards you can have.Is there a limit to how many dashboards we can have in one account - particularly those made global?
jb60606,
I spoke with a developer, and there is a solution that will work for you.
1. Put all of your dashboards into /var/www/html/nagioslogserver/application/dashboards
The dashboard must end in .json and be owned by the nagios user
2. Using your web browser, navigate to <nlsserver>/index.php/install/upgrade/globals
At this point, all of your dashboards will be imported.
Jolson,
Worked like a charm. Thanks again
Regards
Regards
Glad to hear it - I'll lock this thread as resolved.
Best,
Jesse
Best,
Jesse
