quick action item
btemple
quick action item
Post by btemple »
I was wondering if you guys know of a way to run TOP from the Quick Action screen ? I know you can add custom items but I am not sure what script could be run in the background to produce TOP results remotely ?
Re: quick action item
Here's one one you can do it. I have a host that I am monitoring via NRPE. I set up the following command on the remote box (client):
command[check_top]=top -b -n 1
and restarted xinetd:
service xinetd restart
I made sure it works from the command line on the Nagios XI server:
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_top
top - 13:53:09 up  1:01,  1 user,  load average: 1.17, 1.15, 1.69
Tasks: 177 total,   3 running, 174 sleeping,   0 stopped,   0 zombie
Cpu(s): 13.7%us, 10.0%sy,  0.0%ni, 53.0%id, 22.2%wa,  0.3%hi,  0.8%si,  0.0%st
Mem:   4019476k total,  1057168k used,  2962308k free,   187104k buffers
Swap:  2064380k total,        0k used,  2064380k free,   341756k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 1078 root      20   0 34152  14m 3472 R 15.7  0.4   0:07.80 ncpa_posix_list
 1833 root      20   0 47864 4752 2704 S  2.0  0.1   0:30.68 fprobe
26350 nagios    20   0 12240 3632 2520 S  2.0  0.1   0:00.01 sendmail
27007 nagios    20   0  2696 1064  784 R  2.0  0.0   0:00.01 top
    1 root      20   0  2900 1416 1204 S  0.0  0.0   0:02.30 init
    2 root      20   0     0    0    0 S  0.0  0.0   0:00.00 kthreadd
    3 root      RT   0     0    0    0 S  0.0  0.0   0:00.90 migration/0
    4 root
I put the command in a bash shell script, called "top.sh" in the "libexec" directory:
[root@testbox libexec]# pwd
[root@testbox libexec]# cat top.sh
#!/bin/bash
exit 0
I added the command (script) to the "Actions" component:
Admin->Manage Components->Actions->Edit Settings
and clicked on "Apply Settings".
Now, when I click on my host under "Home->Host Detail", I can see the "Top" link under "Quick Actions":
When I click on it, I can see the top output:
btemple
Post by btemple »
this look very good thank you !
ssax
Dreams In Code
Post by ssax »
Check it out and let us know if you have any questions.
btemple
Post by btemple »
This is what we are looking for but, we are going to try to use check_by_ssh instead of NRPE if possible
btemple
Post by btemple »
this is working from command line need to figure out the quick action part...
su nagios top.sh
top.sh
#!/bin/bash
/usr/local/nagios/libexec/check_by_ssh -H xxxxx -C "top -cSbn 1"
exit 0
Need to figure out how to inject the name of the server from the quick action to the -H .....
ssax
Dreams In Code
Post by ssax »
What you could do is edit the quick action and set the command to:
/usr/local/nagios/libexec/top.sh '%hostaddress%'
Then change the top.sh script to:
#!/bin/bash
HOST=$1
/usr/local/nagios/libexec/check_nrpe -H $HOST -c check_top
exit 0
Then you should be golden!
btemple
Post by btemple »
This is the last piece, I need to make the quick action run in the context of my nagios account , I think it's running as root
From the launched screen ...
Running: /usr/local/nagios/libexec/top.sh '172.29.10.169'
Remote command execution failed: Could not create directory '/var/www/.ssh'.
Did you setup password-less login by ssh for that host?
If not, you need to following the instructions below.
https://assets.nagios.com/downloads/nag ... ng_SSH.pdf
For every host you want to use the quick action item, you will need to follow that procedure.
Edit.
I forgot to add that the Quick Action Item runs as apache so the password less login will have to be setup as the apache user.
And the command will have to be edited to use the nagios login like below.
/usr/local/nagios/libexec/check_by_ssh -H xxxxx -C "top -cSbn 1" -l nagios
btemple
Post by btemple »
Ok is there anyway to make the quick launch use the "nagios" account instead of "apache" ?
