Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
Run the following from the CLI as root to attempt to repair the DB
/usr/local/nagiosxi/scripts/repair_databases.sh
Tried running this script, no change. Also tried restarting both the database and nagiosxi servers
output from /var/log/httpd/error_log
[Sun Jul 12 14:59:27 2015] [error] [client 10.x.x.x] PHP Warning: pg_pconnect(): Unable to connect to PostgreSQL server: FATAL: connection limit exceeded for non-superusers in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682, referer: http://nagiosxi.address.com/nagiosxi/
[Sun Jul 12 14:59:27 2015] [error] [client 10.x.x.x] PHP Notice: Undefined variable: result in /usr/local/nagiosxi/html/includes/db.inc.php on line 241, referer: http://nagiosxi.address.com/nagiosxi/
- Box293
- Too Basu
Re: A database connection error has been detected
Is postgresql running?
The logs are named by the day, , for example postgresql-Mon.log
Can you please run this command for the most recent log:
And also:
Post the results here in a code block.
service postgresql statusCan you please run this command for the most recent log:
tail -n 100 /var/lib/pgsql/data/pg_log/postgresql-Mon.logCode: Select all
tail /var/log/messages -n 100As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Was this ever resolved? I'm actually having the same issue.
I think that is a question that only the original author of the topic can answer.
Have these steps been done?
Box293 wrote:Is postgresql running?
The logs are named by the day, , for example postgresql-Mon.logCode: Select all
And also:Code: Select all
Post the results here in a code block.Code: Select all
Former Nagios Employee.
me.
me.
# service postgresql status
postmaster (pid 1914) is running...
# tail -n 100 /var/lib/pgsql/data/pg_log/postgresql-Mon.log
Have you tried increasing the default "max_connections" value of 100 in the "/var/lib/pgsql/data/postgresql.conf", i.e.
and restarting the posgresql?
max_connections = 200Code: Select all
service postgresql restartBe sure to check out our Knowledgebase for helpful articles and solutions!
I did some research on the error message after I posted the results and found I could increase the limit. I have done so only a few minutes ago. I haven't seen any DB Connection errors since but it may be too early to tell.
jdalrymple
- Skynet Drone
We'll leave the ticket open. Reach back out if the problem recurs.
